Clutch start cancel (light)
Discussion in 'Lighting' started by Aww Boo, Apr 1, 2012.
  1. Apr 1, 2012 at 9:35 PM
    Aww Boo
    Aww Boo [OP] Well-Known Member
    Jayson Lee
    Petaluma,CA
    98 tacoma 4x4 manual, 2.7L, (300k club)
    Front and rear trail gear armor Trail gear rock ripper headers skidrow skid plate K&n air intake Headach rack Anzo headlight at 8k Bilstein 5160 rear JBA uca
    Hey so I just realized that the clutch start cancel button light doesn't turn on anymore but I can still turn the truck over. Just bothers me that it doesnt work anymore to let me know if I hit that button or not. If anybody know how to get to the bulb that be great. I tried taking the bottom cover where the fuses are off to try to get to the switch but it looks like I have to take more off, the covers to the vents and only got so far cause I didn't want to break nothing
  2. Apr 3, 2012 at 7:57 PM
    joes06tacoma
    Joe
    Central Coast, CA
    On the second gens, the bulbs twist out of the switches once they are out of the dash. There is a small "plug" on the side of the switch that comes out with a flathead screwdriver. Not sure if a first gen is the same, but figured I'd try to help you out since no one has responded.
  3. Apr 4, 2012 at 2:55 PM
    Aww Boo
    Jayson Lee
    Petaluma,CA
    thanks when i pull apart that side of the dash it looks like its in a casing one of the big fueses under the hood and i need to detach it from the dash and thanks for the help
