Clutch Start cancel switch - only way to start my 97 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by prozac, Nov 5, 2012.
  1. Nov 5, 2012 at 4:55 PM
    prozac
    prozac [OP] Well-Known Member
    Zach
    Shreveport, LA
    1997 Tacoma 3.4L V6 4WD w/Manual Locking Hubs
    Flat Black
    Ok so as the title states here currently the only way I can start my 97 tacoma is to press the clutch start cancel switch.
    I have recently found out this switch is actually intended for the purpose of hills etc so you can start the truck in gear.
    obviously it works fine when hitting the start cancel button first but this seems like a problem to me even though it may be a good theft deterrent ha.
    Is there a sensor etc that could be out and causing this? is something wrong with my clutch?
    I should also mention its a 4wd and obviously a manual.
    Thanks in advance for the help guys
    Zach
  2. Nov 5, 2012 at 5:02 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    Sounds like bad switch on your clutch pedal. So if you push clutch in as far as you can still no connection?
  3. Nov 5, 2012 at 5:02 PM
    DriverSound
    DriverSound Señor Member
    SoCal
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    There is a switch under the dash that your clutch pedal is attached to. Replace that.
  4. Nov 5, 2012 at 6:16 PM
    dark tangent
    dark tangent Well-Known Member
    Madison, WI
    Rigid Dually D2 Amber Driving LEDs mounted on CBI Offroad ditch light brackets.
    I don't understand what you said about the clutch cancel button being used to start the truck in gear. Is that possible? If I would try to start the engine with it in gear and the clutch out, well, something bad would happen. Am I missing something here?
    I always use with the cluth cancel button to start my truck, it's easier, but it's gotta be in neutral.
  5. Nov 5, 2012 at 6:19 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Yup, its to get u out of shitty situations when your engine is dead
  6. Nov 5, 2012 at 6:22 PM
    jberry813
    jberry813 Making TW Great Again Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    This happened to me too.
    Before replacing any switches, stick your head underneath the dash. There is a single 12 mm bolt that goes vertically up into the dash that's attached to a metal bracket connected to the clutch pedal assembly. That bolt came loose on my truck and caused the exact same problem. Three twists with a ratchet and snugged down and problem solved.
  7. Nov 5, 2012 at 7:15 PM
    prozac
    Zach
    Shreveport, LA
    Flat Black
    Sweet thanks for the advice! I'll definitely check that first
    on a bright note it looks like that switch is only about $25 so that should be a cheap fix too I was worried it would be much worse news
    Zach
  8. Nov 5, 2012 at 7:45 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    That bolt came loose on mine and was causing the most heinous rattle for a day...
