clutch start cancel switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rancher 420, May 9, 2011.
  1. May 9, 2011 at 6:08 PM
    rancher 420
    rancher 420 [OP] Well-Known Member
    Adam
    north east ohio
    2011 plain jane 4x4
    aftermarket fogs with HID LEER 100R cap pioneer head unit tinted windows silverstar reverse lights tow hitch cobra 75 c.b. vent visors new recovery hook in the front camping set up in the back ( rug, air mattress, fan, and heat)
    ok... what is the use of a clutch start cancel switch?
    i have one in my truck, but dont know of a logical reason for it.
    any ideas?:confused:
  2. May 9, 2011 at 6:12 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    In the manual!!!!... it states that the Clutch Start Cancel is to be used for when you're trying to start your vehicle while pointing uphill. If you're in gear, it allows you to bypass using the clutch when you start the engine. It WILL bunny hop you forward (since you're in gear), and you can feather the gas and brake pedals as neccesary to get going up the hill.
    Many people use it to just start the truck without having to actually get inside and press down the clutch pedal. You just have to make sure that you're in neutral.
  3. May 9, 2011 at 6:14 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    ding ding ding heres your answer.
    and if your off road in a hairy situation you can put your truck in 1st and bump your self foward using the starter. if you do this alot your starter may go out though
  4. May 9, 2011 at 6:27 PM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    Also if your engine were to die in traffic, you could use the starter to get your truck out of the way.
  5. Jul 28, 2013 at 4:04 PM
    Mac5.56
    Mac5.56 Member
    NY
    Nothing yet that's why I'm here.
    Sorry to revive what is probably an ancient thread, but can you also have this button activated while off roading and will it allow you to not have to depress the clutch in really slow crawls that would normally stall the truck?
  6. Jul 28, 2013 at 4:06 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    No, you would have to feather the clutch on that one. It would still bog down the engine, you would just have to give it some gas and feather the clutch.
    BassAckwards likes this.
  7. Jul 28, 2013 at 4:11 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    All the clutch start cancel switch does is allow the starter to be turned while the clutch is not depressed.
    its not designed to even start the engine while in gear, its designed to get you up a hill by cranking the engine until you are to a point where you can start it normally.
    Takes some practice to get those slow moving rolls. re-gearing helps.
    shakerhood likes this.
  8. Jul 28, 2013 at 4:40 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    I used it once in my 92 to help a guy pull me out of a dry riverbed (truck would not start). same truck I used it another time to start it while I was working on it. didn't want to get in as I had my seats forward to put tools away. it crashed into my workbench before I could shut it off.
    I have never used it in my 08 as apparently, im never really sure when a truck may or may not be in gear
  9. Jul 28, 2013 at 4:41 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    To be used in 4lo for offroad hill starts.
  10. Jul 28, 2013 at 7:06 PM
    ouyin2000
    Nova Scotia
    '11 DCSB TRD Sport
    ...seriously? That's straight up derp right there...
    Braco likes this.
  11. Jul 28, 2013 at 7:46 PM
    92dlxman
    Kevin
    Visalia, CA
    yes imagine a self-respecting guy, proud of the work he just finished, yanking the seat-back backwards, and climbing in for the clutch and or key as the truck inches moreso and moreso into my bench/ wall. it was in 2lo which was good and bad.
    one of my derpest moments for sure. I've been pretty sure of my gear selection since then. but again, never 100%:eek:
  12. Sep 14, 2022 at 1:13 PM
    maunman
    maunman Member
    I even moved mine, in an older Toyota 4wheel drive, over to the switch knockout holes in the middle of the dash (under the climate controls) so I could easily reach the switch from the passenger side or driver side because I used it so often just to get the engine warming up without having to climb into the driver seat. But I have a very strong habit of making sure it’s not in gear.
