Clutch Start Cancel?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by alx_alx_69, Dec 23, 2009.
  1. Dec 23, 2009 at 6:21 PM
    alx_alx_69
    alx_alx_69 [OP] Well-Known Member
    Alex
    Hope Mills, North Carolina
    Does anybody really know what the clutch start cancel is for, in the owners manual it says for extreme situations, not for normal use.
    Extreme situations like what, my legs were eaten by the cougar in my passenger seat? The only thing I can think of this being used for is to start my truck in the morning without having to climb in and push in the clutch, but the manual also says not to use it on a daily bases so WTF?
  2. Dec 23, 2009 at 6:22 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    It's for lazy people who don't want to push the pedal in to start... :laugh:
    and maybe for people who's legs were eaten by a cougar... :laugh:
  3. Dec 23, 2009 at 6:25 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    its like the ladies helper in pool..not needed..but can make life alot easier
  4. Dec 23, 2009 at 6:36 PM
    bigyetti
    bigyetti Well-Known Member
    mike
    asheville, nc
    08 taco dc 4x4 short bed
    sirius satilite radio, more on the way when i get more money. oh ya removed the secondary filter
    it makes it easy to start the truck while servicing, timing adjustment. or it stalls out at a red light and wont restart you can get it off the road out of harms way. just my .02
  5. Dec 23, 2009 at 6:40 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    It is for extreme situations off road. For instance, you are climbing a steep grade in 4 low and your truck dies. instead of having to apply the brakes and push the clutch in, you can push the clutch cancel button and apply a slight amount of throttle while starting the engine. The truck will start and you do not run the risk of rolling backwards off a cliff.
    PacTaco likes this.
  6. Dec 23, 2009 at 6:42 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    If you stall the truck on a steep hill and you are afraid to push the clutch in because you like living you use this button ^ what he said
    PacTaco likes this.
  7. Dec 23, 2009 at 6:48 PM
    Yota1
    Yota1 Well-Known Member
    i find this funny too, if you are in the situation as above, your right foot is on the brake anyways, or it should be. so your right foot is should be near the clutch anyways, i mean if your in that situation you are on and off the clutch anyways.
    i have used it a few times, but mostly when i want to reach in a start the truck, instead of getting in a depressing the clutch
    I think it is mostly for the use of remote start, it makes it easier to wire in the systems with a standard trans with these switches
  8. Dec 23, 2009 at 6:48 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I don't think it was made for staying alive rather than falling off of a cliff, but it does work that way. I believe being a button that "cancel"s the need to push the "clutch" in while you "start" the truck, it is used for starting the truck without having to get in
  9. Dec 23, 2009 at 8:08 PM
    revhappyleon
    revhappyleon Well-Known Member
    Manny
    Tampa near macdill
    07 Prerunner V6 6-speed(custom dual exhaust)
    dual exhaust, foglight anytime, satoshi, chlm, aux backup lights and electric fan conversion
    I think it's for starting on a steep hill otherwise why would it only be on 4x4 models
  10. Dec 23, 2009 at 8:11 PM
    dwalden2
    dwalden2 HBTFD
    Derick
    Blue Ridge, Georgia
    '05 TRD Offroad V6 6 spd
    SCS Stealth 6 Wheels, 285/70/17 STT Pros, Demello Offroad front bumper, 20" LED Bar, LED Fogs, LED interior lights, Wet Okole Seat Covers, Body Armour Rear Bumper, Smittybilt 10K winch, 3" OME Lift
    I just use it on cold mornins when I go to warm the truck up...or when I tell the woman to go out and crank it. I'm always afraid she'll leave it in gear and let the clutch out, so i make her put it in neutral and use the Clutch Start Cancel.
  11. Dec 23, 2009 at 8:14 PM
    blackxpress
    blackxpress Well-Known Member
    Jeff
    Carlisle, OH
    98 SR5 2WD Xcab
    Would it also make it possible to push start it if you have a dead battery? Mine doesn't have one of those switches but I think I might wish it did. I left my lights on recently and didn't have any jumper cables. I tried to roll it down the hill and dump the clutch but it wouldn't start. I'm guessing that's because it won't start unless you hold the clutch pedal to the floor. Am I right about that?
  12. Dec 23, 2009 at 8:19 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    works for starting the truck on steep boat ramps also
  13. Dec 23, 2009 at 8:25 PM
    SC4333
    Grant
    FL
    The clutch start cancel is specifically for starting the truck on a hill without the clutch, while in gear. Nothing more, nothing less. It was by no means intended to be used as a lazy mans way of starting the truck, and it is mentioned in the owners manual to not use the feature for anything other than "extreme situations" which would be the previously mentioned situation.
    Exactly. Common sense prevails again.
  14. Dec 23, 2009 at 8:26 PM
    TacoMOnster07
    TacoMOnster07 Well-Known Member
    Pennsylvania
    07 DC 6speed 4x4 BSP Sr5
    BHLM, Grillcraft, Urd SS, Urd TCAI, Urd MAF Calibrator, AeroTurbine Exhaust, TacoTune Single Din, Two 8" Infinity Subs, 12-13000 HID's, Xtreme Bedrack light bar with two KC 4 by 6 lights.
    Using the clutch start cancel will wear parts. I believe it also let's your starter help move your truck forward if your off the brake. Like said before this is helpful if you stall on a hill and need to give a little gas to get going.
  15. Dec 23, 2009 at 8:27 PM
    Blumpkinson
    Blumpkinson Fuelled by plutonium and wild animals
    OR
    03 4x4 5spd
    Can you just have it in first gear and turn it over when the button is pushed?
  16. Dec 24, 2009 at 12:55 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Yes...its made to be used in 4low, where your starter can move your truck without it running. Thats why its not on 2wd trucks...because they do not have the superlow 4low gear ratio.
    put the truck in 4low...push the clutch cancel...start your truck...give it some gas and off you go.
  17. Dec 24, 2009 at 5:29 AM
    Blumpkinson
    OR
    03 4x4 5spd
    Damn that freaking sweet, im looking foward to stalling on a hill now:D. Im assuming it's not something i should use very often.
  18. Dec 24, 2009 at 5:37 AM
    BSP4x4
    BSP4x4 Guest
    ^ remember...it's for 4L....how often are you just cruising along in 4L?
  19. Dec 24, 2009 at 5:58 AM
    Blumpkinson
    OR
    03 4x4 5spd
    Not very often, but when trying a hill climb it would be pretty fun to test it out.
  20. Dec 24, 2009 at 6:57 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    That's what I use it for every day without exception. The truck still works, no problem.:D
