Clutch start cancel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by no_werries, Apr 3, 2008.
  1. Feb 27, 2009 at 4:26 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I just permanently bypassed the clutch cancel button on my 98 Corolla years ago. Metal staple bent in to a small U shoved into the pins on the plug that comes off the button under the clutch, and black taped over it. :D
  2. Feb 27, 2009 at 5:05 PM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    I thought about that, but I don't think the wife would get it if she drovve the truck.... :frusty:
    Where's the switch on the clutch at? I wonder if I could get the Toyota switch and just rig it up... Anyone who's pulled the switch panel off happen to take a pic of how many wires go to that switch?
  3. Feb 27, 2009 at 5:29 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Though not recommend, you could also use it to get through to high of water if you f*ed up
    :rolleyes:
  4. Feb 27, 2009 at 5:33 PM
    piercedtiger
    Jon
    Southern Tier, NY
    My wife does fine with the car! :D It's mechanics, valets, etc that concern me.
  5. Jul 18, 2012 at 10:26 PM
    driftnut56
    driftnut56 New Member
    Peter
    Edmonton, AB
    Still looking.
    you can shift gears without a clutch. ;)
  6. Jul 18, 2012 at 10:27 PM
    driftnut56
    Peter
    Edmonton, AB
    Still looking.
    The staple doesn't get hot? Staples don't conduct electricity well...
  7. Jul 19, 2012 at 5:44 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The best method for starting on a hill/obstacle is proper clutch operation: Let up on the clutch pedal while holding the brake, while the clutch is partially engaged(which is now holding the truck, with a drop in RPM evident), let off the brake and accelerate while engaging the clutch completely.
    Practice is necessary to perform this in pressure situations accurately. Using the parking brake is a poor practice and will not hold you on an obstacle(it is also slow to release=stall). The clutch cancel will work, but is very hard on the starter. It will usually require you to be in 4lo/1st gear to start out on an obstacle, and will not be strong enough to keep the engine running on steep/large obstacles.
    I use it when I'm too lazy to push in the clutch...
    Willbeck likes this.
  8. Jul 19, 2012 at 6:14 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Why wouldn't they conduct well? They're metal and only need to conduct a small amount of voltage for a few seconds while the engine was starting.
  9. Jul 19, 2012 at 6:48 AM
    ScreamingTaco
    ScreamingTaco Huge Member
    2012 TRD Off-Road AC
    Goodyear Duratracs, TRD cat-back exhaust, bed tool box, bed extender.
    If you're stuck in a bowl or on a steep incline and there's no other way out aside from revving the engine and slipping the clutch, it's a lot cheaper and easier to replace a starter than it is a clutch.
  10. Jul 19, 2012 at 7:20 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    When properly excecuted, clutch slippage is momentary. When poorly done, overheating, smoking, and failure can be the result.
    The starter should be a last resort, not a go-to.
  11. Jul 19, 2012 at 7:30 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Ever been on a STEEP HILL and needed to start or restart your truck--Damn switch is HANDY--dont have three feet----gas-clutch-brake.-- solves the probem.
  12. Jul 19, 2012 at 7:50 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    this has been covered before in detail.
    however useful it maybe if your stuck i don't think i would ever rely on my starter to move my truck out of anything that has that much suction like mud or force against it like going up a hill. wearing out your starter is one thing breaking it is another that is a sure fire way to leave you stranded and i can see it happening rather quickly in the situations described above.
    this is why you buy a winch imo, with that being said i use mine everytime i start my truck i make sure its in neutral i insert the key hit the button and fire her up never had a problem in 2 years.
    toyota would not have put it there if it was only supposed to be used in certain circumstances because in general most floks never touch the owners manual even if they have them so there would be instances of them breaking constantly if that was case.
  13. Jul 19, 2012 at 7:52 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    on a side note i have never heard of the clutch start cancel button being directly attributed to a malfunction or breakage of any kind when being used in either everyday life such as starting your truck constantly with it or using it to quote get unstuck so.
    but, for me personally to use it for the purpose of getting out of a mud pit or up a steep hill i would have had to exhaust every single option winch being pulled out or using my head and digging and using a high lift just my .02 take it or leave it.
  14. Jul 19, 2012 at 8:08 AM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    I love my switch....use it all the time to start the truck without having to get in....especially for warm up in the winter!!
    Just make sure you are out of gear before turning the key if you are not in the truck!!!
    I have never tried it in a situation where I am stuck....yet!!
  15. Jul 19, 2012 at 10:33 AM
    #35
    ScreamingTaco
    No sh*t...
    ...next up, the sky is blue.
  16. Jul 19, 2012 at 10:59 AM
    #36
    PaintDrinkingPete
    PaintDrinkingPete Well-Known Member
    NoVA
    2012 4x4 TRD Sport DCSB
    Great for getting car warmed up *before* you take your ski boots off!
  17. Jul 20, 2012 at 4:45 AM
    #37
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I offer more compelling evidence backing my opinion. You? Smart-ass BS. Blue sky is an illusion of swamp gas coming out of Uranus:p
  18. Jul 2, 2016 at 4:44 PM
    #38
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    Spot on, if you can do this you truly know your truck.
  19. Jul 3, 2016 at 10:02 AM
    #39
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I'm in the use it in winter crowd. Start it up and go clear the snow/ice. As for the few posts on potential damage I agree it will not do anything. It is just an electrical component that bypasses the lower clutch switch. If you are in neutral there is no difference to anything mechanical.
    I'd really have to be up the creek without a paddle to limp the truck on the starter, but it is nice to have the option.
