Clutch/Throwout Bearing Issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by billnsandi, Oct 11, 2009.
  1. Oct 11, 2009 at 6:59 PM
    billnsandi
    billnsandi [OP] New Member
    Hey all, new member here with a new to me '04 xcab 4x4 2.7 5 speed - 130k miles.
    Just drove it home from California about 800 miles and it did great, averaging about 22 mpg at 85 the whole way.
    Now for some troubleshooting -
    When idling at rest with the clutch out in neutral it has a noticeable "whirring" sound coming from the tranny/back of engine area. It completely goes away when the clutch is on the floor - but you can hear it until the clutch is nearly to the floor. When the clutch is completely depressed there is no sound. It sounds vaguely "dry bearingish" You can accentuate it with reving the engine a bit.
    I did a bit of searching and didn't come up with alot. Doesn't appear to be a clutch pedal adjustment issue (same whirring until clutch is completely depressed).
    So I am thinking - throwout bearing, pilot bearing or input shaft/bearing (mostly a 6 spd issue no?)
    Any thoughts? I will likely pull the tranny and throw a fresh clutch/throwout bearing in it anyways.
    Any thoughts on replacement clutch parts? OEM? Mail order? Parts store?
    Thanks for the help
  2. Oct 11, 2009 at 10:35 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Hi & welcome to TW:
    It sounds like you have your finger on it in regards to the throw out bearing especially because it goes away when you depress the clutch, as long as the release is good still ( smooth ,no slipping when pulling away, etc:) You still have a little life in it but if you're going to change it anyway also change the other parts like pilot bushing etc: & check the flywheel carefully for the usual heat cracks , glazing . I generally pull the flywheel anyway & get it surfaced. Good Luck....:cool:
    P.S. as far as parts go, I'm an OEM guy but there's some good aftermarket performance parts out there, it just depends how much you want to spend.
  3. Oct 12, 2009 at 6:05 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    X2 on the "replace them while you are in there"
  4. Oct 12, 2009 at 9:34 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    He has a first gen so that wouldn't be relevant.
