Clutch time
Discussion in 'Technical Chat' started by Von Himmel, Jun 27, 2013.
  1. Jun 27, 2013 at 7:32 PM
    Von Himmel
    Von Himmel [OP] Active Member
    James
    Pendleton
    01 TRD SR5
    I have a 3.4 TRD and am about to replace my clutch. Any words of help or tips are greatly appreciated! Any How-to's? Any tool lists? Any "easy way to do it"?
  2. Jun 28, 2013 at 5:40 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    There really is no "easy" way to do this. First step is obvious: Remove the transmission. If you are doing this in a shop it will be easier, but if you are tackling it in a driveway, it will pose a bit more of a challenge. You will want to chock the rear wheels to prevent any unwanted movement. Next go through the shifter area to remove the transfer case shifter and the transmission shifter from the top of the transmission. Remove both driveshafts. After that you can use a jack to support the transmission/transfer case while removing the crossmember. Disconnect all electrical connectors from the transmission. remove bellhousing lower cover. Unbolt transmission and remove. Now you have access to the clutch. Most of the bolts you will run into for the entire job will be: 10mm, 12mm, 14mm and 17mm.
  3. Jun 28, 2013 at 5:43 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    this^
    Dad (a mechanic) changed the transmission in my truck 2(?) years ago in our driveway, it took 3-4 evenings, and i'd assume just swapping trannys was easier then replacing the clutch.
  4. Jul 7, 2013 at 9:00 PM
    Von Himmel
    James
    Pendleton
    01 TRD SR5
    So here is how I did it: in a drive way with a buddy, lifted the truck up on my old rims for clearance, didn't use a trans jack just used some ratchet straps on the frame, pulled trans tranny, pulled the old clutch out (missing two fingers as well as most of the throw out bearing) replaced it with new one and put it all together. Took us about 24 hours and 30 beers in 90 degree heat but all in all, not too bad. Hardest part was the top blots for the tranny, had to drop the back end of the tcase dow a bit to get access to the two top bolts. Went through the cab with a long extension for them after squeezing my hand up there. No real difficulties doing it, just a pain to get those two top bolts.
    If anyone needs more detail for when you have to do it let me know, I can pretty much walk you through it now:D
