Clutch/Transmission Problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by DKbik3r, Nov 10, 2016.
  1. Nov 10, 2016 at 6:09 AM
    DKbik3r
    DKbik3r [OP] Well-Known Member
    Daniel
    Springfield MO
    1st Gen Taco/3rd Gen 4Runner
    Hello everyone i am very sorry for my horrible spellingthat being said i have been having some clutch/tranny problems im not sure witch it is but its getting bad. i have an 2003 tacoma 3.4 5 speed and if im at a light it wont go into first sometomes so i try and go through all there gears to see if i can get it in any and it takes a little bit but i can aventaly get it into 2ed then back into 1st. itll also make a loud klunk when going into each gear once in awhile itll grind in some gears also mainly 3ed and 4th i have no clue what it is and i need some help if you know anything let me know please!
  2. Nov 10, 2016 at 11:25 AM
    MattFL
    MattFL Well-Known Member
    S. Florida
    1999 Tacoma V6 4x4 TRD Extended cab
    Does the clutch pedal feel normal? Make sure you're not low on clutch fluid and that the pedal works as normal. If there's air in the system and/or it's low on fluid then the clutch might not disengage completely, which will definitely make it difficult to shift. Does this sound like your problem? A bad throw out bearing could also have the same effect.
    Does it shift smoothly if the engine is off, or if you're rolling at a slow speed?
  3. Nov 10, 2016 at 11:25 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
  4. Nov 10, 2016 at 1:10 PM
    eon_blue
    Azusa, CA
    How many miles are on your clutch?
