CLUTCH TSB-0066-11
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JJPF, Jan 16, 2012.
  1. Jan 16, 2012 at 3:40 PM
    JJPF
    JJPF [OP] Member
    Dillingham Alaska
    07 access cab sr5 2.7 5 spd
    Hello- the clutch on my 07 2.7 4x4 has been slipping and now started to vibrate intermitantly under load- I found a website talking about TSB -0066-11 for this problem but I dont see it listed on the TSB thread any info appreciated. Any other 5 speed clutch troubles on here?
    JJPF
  2. Jan 16, 2012 at 4:11 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    only problem with mine is when it gets below zero, and it takes a little bit to warm up, it almost sticks for a second when fully depressed, then gets back to normal after it warms up. No slipping at all.
  3. Jan 16, 2012 at 4:12 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I had my clutch replaced for free after only 10k miles. From my understanding toyota used two different clutches one made in USA and one made in Japan. apparently the ones that are failing are the usa made clutches. I got this info from a toyota tech so I have not verified this anywhere else
  4. Jan 16, 2012 at 4:45 PM
    JJPF
    JJPF [OP] Member
    Dillingham Alaska
    Do you have a copy of the tsb- I've only been able to find reference to it not an actual copy.
  5. Jan 16, 2012 at 6:06 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    I will have to research it for you. I will call my tech tommorrow
  6. Jan 16, 2012 at 6:21 PM
    AKTACO420
    AKTACO420 Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    I'm about to go through this as well my clutch is slipping in 4th and I have 35000 miles. I hope they will cover it under warranty
  7. Jan 16, 2012 at 6:54 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    You should be fine at 35K......don't wait though...after you pass 36K they could try to get out of it.
  8. Jan 16, 2012 at 7:29 PM
    AKTACO420
    RETODD
    Anchorage AK
    2009 tacoma
    I'm trying not to wait but the dealer ship is 150 miles away and I'm stuck in school during the week. If they can't cover it I'm going to do it myself at school we got all the tools and a lift. I've got a question I took the truck in because my transmission was making a chirp sound and they said it was nothing could this be the problem. My teacher thinks it's the throw out bearing. Any input would be nice
  9. Jan 16, 2012 at 9:54 PM
    JJPF
    JJPF [OP] Member
    Dillingham Alaska
    Seems like the cold definatley has an effect on this. We are in a 3 wk cold snap right now. I talked to the dealer this morning and they told me it would be covered under the 5yr/60k power train warranty. I'm off the road system so can't bring it to the dealer having a local shop do it. We'll see how it pans out. J
  10. Jan 16, 2012 at 10:01 PM
    tbturner47
    tbturner47 Well-Known Member
    '16 Barcelona Red TRD Off Road
    its prolly the TOB. there is a tsb for that as well.
  11. Jan 16, 2012 at 10:12 PM
    AKTACO420
    RETODD
    Anchorage AK
    2009 tacoma
    I know how you feel it has been well under 0 degrees but I got to Seward lastnight and it's been warmer and it isn't doing it as bad. I'm glad to see I have a chance at the warranty hopefully the op will have good luck
  12. Jan 17, 2012 at 8:43 PM
    JJPF
    JJPF [OP] Member
    Dillingham Alaska
    Anybody? I saw a write up on it @ TacomaHQ but no link to the actual TSB- my mechanic checked- I'm not sure what website but said he couldn't find it. thanks-Jjpf
  13. Jan 21, 2012 at 10:54 PM
    AKTACO420
    RETODD
    Anchorage AK
    2009 tacoma
    Anybody find anymore info on the tsb the dealer wants 1200
  14. Jan 22, 2012 at 1:14 PM
    JJPF
    JJPF [OP] Member
    Dillingham Alaska
    I paid the dues to the TIS and printed off the TSB-0066-11 It says it's covered within the 3yr/36k period which sucks because mine is an 07 with 37k on it so I'm sure they are gonna deny but I'm going to give it a shot. What do you you think they will say?
  15. Jun 4, 2012 at 2:31 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    I am having this done to my truck, but i fear they have ordered the bad parts again given the parts the told me don't match other listsings. Can someone please post the clutch and pressure plate part numbers that are listed in this tsb?
    Edit I found the tsb and dealer is going to use the correct parts listed.
  16. Jun 5, 2012 at 6:59 AM
    knucklehead
    knucklehead Well-Known Member
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    There have been about a thousand revisions. Proper parts, as of now, are pressure plate 31210-35291 (aisin ctx-107), disk 31250-60500 (updated aisin dtx-136).
    Note that some of the older revisions included an aisin ctx-106. The ctx-107 is a "heavy duty" compatible pressure plate and matches up to the first gen V6 (a more powerful engine). the ctx-106 matches up to the first gen 2.7 (a weaker engine).
  17. Jun 5, 2012 at 7:10 AM
    jassco
    NH
    2023 TRD Offroad
    Great, so from the parts on my repair form I'm getting the older V6 plate and flywheel. If that breaks/wears easily then this engine is stronger then we think!
