clutch warranty
Discussion in '4Runners' started by 511000 mile 4runner, Apr 28, 2023.
  1. Apr 28, 2023 at 9:27 PM
    511000 mile 4runner
    511000 mile 4runner [OP] New Member
    jo
    1990 toyota 4 runner 511,00 miles
    I have a 1990 toyota 4 runner. best care ever with 511,000 miles well maintained. The clutch died with 30,000 miles and toyota would not cover because "car is too old"
    In the last two years, toyota has sent knox sensor switches - 2 defective but new, 2 cold dead start switch - one was defective, 2 radiator hoses - one was defective, a wrong part
    and now the whole clutch replacement including flywheel
    I have my car serviced at an independent shop with excellent service and people that know what they are doing. I have stated that I do not want anymore toyota parts unless that is the only place on earth to get one.
  2. Apr 28, 2023 at 9:30 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I feel your pain, I have a 1991 FJ80. Toyota does not offer any real warranty on those parts—if they even still make them.
  3. Apr 28, 2023 at 9:41 PM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    Are you / the shop ordering direct from a dealer? Even OEM will have bunk parts once in a great while, but that seems like an awful lot of failures for genuine new Toyota parts
    I only ask because fake parts are a very common scam these days. You can order a "genuine" Toyota part, it'll come in what looks to be real packaging, but it's really just a cheap aftermarket copy. Ebay is particularly bad for that. Not to say that's the case here, but unless the parts are coming from a really reputable place, I'd be suspicious that you could be getting fake aftermarket crap wrapped up in a Toyota box / bag.
    If they are legitimate, then that's some extraordinarily bad luck and I definitely understand the frustration
    TartanEagle likes this.
  4. Apr 28, 2023 at 9:58 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    How did the “whole clutch” go out?
    Did the pressure plate fail? How did the flywheel fail too?
    Was it a new flywheel? Or a resurfaced flywheel?
  5. Apr 30, 2023 at 5:07 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I deliver parts for a Toyota dealership. Most of the shops I deliver to will only order genuine Toyota parts to install in their customer's cars if they can't get an aftermarket part. Why? Because aftermarket parts cost them less, so they make more money.
    Why do I bring this up? Because most shops tell their customers that they install "Toyota parts" when they actually don't. When they say "Toyota parts", they're actually saying "parts that fit a Toyota." There's a big difference there. And generally speaking, aftermarket parts just don't work as well or last as long as OEM Toyota parts.
    So OP, what kind of parts was / is your shop putting in? I highly doubt true OEM Toyota parts would fail at the rate you're seeing in your vehicle.
    BTW, sending the wrong part (radiator hose) does not mean it's defective.
    Unner, SH10151 and TartanEagle like this.
  6. May 6, 2023 at 9:26 AM
    Too Stroked
    Tom
    Still waiting for a reply from the OP. Silence - to me at least - means she found out her shop was installing "parts that fit a Toyota" instead of "genuine OEM Toyota parts." Having driven Toyotas since 1976 and working for a dealership in Parts & Service, I can assure you all that genuine OEM Toyota parts bought from a Toyota dealer (not eBay) virtually never fail the way the OP stated.
    2Toyotas likes this.
  7. May 6, 2023 at 9:29 AM
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    Yeah.
  8. May 6, 2023 at 9:39 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Even if they are using “genuine Toyota parts”, at this point the vehicle is so old the “Toyota” parts available for it are likely not the actual oem stuff anymore. As vehicles become ancient the OEM quits making stuff but the parts departments continue sales by reboxing other stuff. Mopar was notorious for that, the water pumps originally were way better on my Jeep long ago, these days what you get in the box is the same crap as you get from the parts store. Same for starters and alternators, and sensors. Just because it comes in a Mopar box doesn’t make it original. Likely the same as Toyota with that much age.
