Clutch Whine/Noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by socalkid, Aug 2, 2017.
  1. Aug 4, 2017 at 2:18 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Not with the 4cyl they don't, they have a W59
  2. Aug 4, 2017 at 3:42 PM
    socalkid
    socalkid [OP] Member
    Ventura County
    98' 4Runner 3RZ 5spd 2wd
    yes, yes... that's right, my bad. been outta the game for 10 years, its still slowly coming back to me...
    Dalandser likes this.
  3. Aug 8, 2017 at 3:28 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Could have sworn I saw a used 5 speed box out in Simi pretty cheap on CL the other day
  4. Oct 5, 2018 at 6:12 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    OP, did you ever find out what was causing the whine? I just started getting the same symptoms in my w59.
  5. Feb 5, 2019 at 4:45 AM
    tacopashka
    tacopashka Well-Known Member
    2000 tacoma
    Did you ever find out what it was?? other forums are saying its the input shaft whining..
  6. Feb 6, 2019 at 4:12 PM
    1997tacomav6
    Denver
    Had these exact same issues, ended up being both the pilot bearing and the input shaft bearing on the transmission at
    583,000 miles for me.
    tacopashka likes this.
  7. Aug 30, 2019 at 5:51 PM
    pullingin
    pullingin Well-Known Member
    @1997tacomav6 Just started having this same issue.
    Reading over test you posted for step #1, dont you have to fully press the clutch to start the truck? Is it implied to let the clutch out after starting or should it stay pressed fully in?
  8. Aug 30, 2019 at 6:47 PM
    1997tacomav6
    Denver
    Yup, end replacing all the parts because you have to drop the transmission and the noise is gone.
  9. Aug 30, 2019 at 9:08 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I have a whine with mine when at idle in neutral. Goes away when clutch is pressed. I inquired about it here on Tacoma World quite a while back and everyone said it's a normal noise the 4 cylinders with the manual make. I haven't worried about it and it hasn't bothered anything so far. They said it is just the sound of the input shaft spinning in there. I just ignore it.
    Currygoat likes this.
  10. Sep 1, 2019 at 10:34 PM
    pullingin
    I have been doing more research and there is a chance the fork needs a little white grease. Not sure if the noise is coming from pivot on the fork or where the fork connects to the TOB? It is a very tight location after looking it over this evening. I cant see much once the boot is off and don't want to get too much grease in there!
