Clutch wine noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trevorfox34, Dec 2, 2013.
  1. Dec 2, 2013 at 10:51 PM
    Trevorfox34
    Trevorfox34 [OP] Member
    Trevor
    Louisiana
    '96 taco
    None yet, recently purchased
    I hear a wine when I let off the clutch...it quits when I'm in neutral and I let off the clutch..but as soon as I slightly push the clutch it starts making a wine...before the clutch even engages, you can hear it wine..if anyone can help me i would greatly appreciate!
  2. Dec 3, 2013 at 7:01 AM
    30coupe
    30coupe Well-Known Member
    Russ
    Iowa
    '04 SR5 TRD 4x4 ExCab 5 spd.
    Throw-out bearing is a good possibility. That's what it sounds like to me.
  3. Dec 3, 2013 at 7:12 AM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Generally clutch noise with the pedal down is going to be the throw out bearing. If that is the case, when you replace it only use an OEM Toyota part. Aftermarket clutch kits are fine, but go OEM on the throw out bearing (even though a clutch kit will come with one).
  4. Dec 3, 2013 at 11:07 AM
    Trevorfox34
    Trevor
    Louisiana
    '96 taco
    I thought throw out bearing made a cricket/chirping noise? This noise I'm hearing is just a constant squill as soon as I start pushing the clutch in...it's not unbearably loud and it only does it while I have it in gear and the clutch pushed in and while I'm driving..setting in neutral with no clutch, it makes no noise
  5. Dec 3, 2013 at 12:06 PM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    I have learned that throw out bearings can make different noises. I have replaced some that made a bit of a rrrr noise when pushed. The last one made noise when it was released. That one confused me. When you put slight pressure on the pedal, it stopped. It was an OEM Toyota bearing. Put another OEM Toyota bearing in and all is good.
