Clutch Won't disengage
Discussion in '1st Gen. Tacomas (1995-2004)' started by goomba, Mar 31, 2011.
  1. Apr 1, 2011 at 8:32 AM
    goomba
    goomba [OP] It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    My trany seems to be leaking red fluid. it is defiantly not engine oil.
  2. Apr 1, 2011 at 8:56 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    :confused: from where exactly on the tranny?
  3. Apr 1, 2011 at 9:05 AM
    goomba
    Josh
    San Antonio Fl
    It sems to come from top pass and the rear or the trany near the t case
  4. Apr 1, 2011 at 9:31 AM
    98tacoma27
    Ben
    Not Beech Creek
    Driver side = left side
    So the fork moves forward and back but it will not disengage the clutch and you have a squeak. It could be a bad throwout bearing. You can pull the boot out a little and see if you can see inside. The bearing is only held on with a spring clip. It sounds like the clutch just needs replaced.
  5. Apr 1, 2011 at 9:38 AM
    goomba
    Josh
    San Antonio Fl
    Ya i has a really bad squeal when the clutch was depressed, but that was when it was working. Now it is just a squeek when i am moving the clutch petal in and out.
    He is some picks of the trany
  6. Apr 1, 2011 at 9:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    In this pic above, is that gear oil on the bell housing (towards the bottom of the pic)?
  7. Apr 1, 2011 at 9:46 AM
    goomba
    Josh
    San Antonio Fl
    I think so. it is red, but does not smell like differential fluid. Defiantly not motor oil.
    I am somewhat mechanically inclined. I have replaced the valve cover gaskets and a oil pan gasket on my truck.
  8. Apr 1, 2011 at 9:51 AM
    98tacoma27
    Ben
    Not Beech Creek
    Hmmm, seems like you might have two issues; a leaking tranny and a bad clutch. It looks like your input seal (main shaft seal) maybe gone in the tranny.
    This is what I would do if it were me
    1). verify clutch fork is moving
    2). If clutch fork IS moving like it should, pull tranny and inspect clutch components.
    3). If clutch fork IS NOT moving like it should, trouble shoot clutch hydraulic system (bleed, new fluid, etc.)
    4.) After trouble shooting and clutch will still not disengage, return to #2.
  9. Apr 4, 2011 at 6:06 AM
    goomba
    Josh
    San Antonio Fl
    My truck just started magically workin again, i am so confused.
  10. Apr 4, 2011 at 8:52 AM
    98tacoma27
    Ben
    Not Beech Creek
    :notsure:
    I'm leaning towards a bad master clutch cylinder. Have you checked the linkage to the pedal?
  11. Apr 4, 2011 at 5:47 PM
    mike92y
    mike92y Well-Known Member
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    OME all around. SPC UCA. This and that.
    Exact same thing happend to me. I Replaced the master cylinder as I could see a small amount of fluid leaking from it. Do the slave cylinder while your at it. Slave is like $60 dallors more. Remove drivers side wheel to get easier access to slave. Bleed the line. I used Asin parts. Good luck.
  12. Apr 9, 2011 at 12:45 AM
    Tliv05
    Tliv05 Member
    Taylor
    Colorado
    2003 Toyota Tacoma
    ARB bumper, sound system, Duratracks, AR wheels, K&N filter, Rhino lined, lots more to come
    Had this happen on my 03. not sure what your pedals are doing but I would agree with the slave going out. if the pedal is stuck to the floor and your levels are low its probably the master. Check all your connections to your cylinders also cause mine loosened up driving trails and such. As for any squeaking or creaking from inside the truck, the knuckle on the pedal sucks and toyota actually redesigned it like a year or two ago and you can get a stock or an aftermarket one that is steel. I had a creaky pedal and broke two of those damn knuckles before I figured that one out... apparently i like to slam on my clutch, oops. hope that helps some
