Clutch
Discussion in '1st Gen. Tacomas (1995-2004)' started by Codycode45, Aug 22, 2016.
  1. Aug 22, 2016 at 8:02 PM
    Codycode45
    Codycode45 [OP] Member
    98 tacoma 3.4 4x4 sr5
    Is there a way to adjust your clutch to make grab better or last longer it's starting to slip a little I've heard this want to know if it's bs
  2. Aug 23, 2016 at 1:01 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Maybe when it is brand new or you have installed a new Clutch master cylinder
    Being Hydraulic it is pretty much self adjusting over the life of the clutch.
    Slipping because something is broke or loose might be fixed.
    Slipping because of wear time to thing about a new one
  3. Aug 23, 2016 at 4:52 AM
    98tacoma27
    Ben
    Not Beech Creek
    No. If it's starting to slip then it is time for a new one.
  4. Aug 23, 2016 at 5:30 AM
    Bxnanaz
    Bxnanaz Well-Known Member
    2021 Tacoma TRDOR 6MT
    You can adjust your clutch pedal though. You want it adjusted to where you have a small amount of "play" in the pedal, that way you know the clutch is completely engaged when you release the pedal. The way I adjusted mine is feeling it by hand, there should be a pretty distinct point where it gets harder to push.
    To adjust, lay under the dash and look for a metal rod going from the clutch pedal, through the firewall (this goes into the master cylinder). Loosen the lock nut and spin the rod to adjust (tighten for too much play, loosen for no play.)
  5. Aug 23, 2016 at 5:48 AM
    Clearwater Bill
    Billy
    Largo Florida
    How many miles?
    How many times abused?
    Is the primary driver a clutch rider?
    They don't last forever, although 150k would be pretty reasonable for a well treated one.
    Mechanical clutches have a cable for actuation, and typically need adjusting throughout the life of the clutch. Hydraulically actuated clutches tend to be self-adjusting, as long as there is enough fluid in the reservoir.
    The good news is your BS detector seems to be in order. Yes, you can adjust pedal travel, but that's not the same as adjusting the clutch for wear compensation. And hydraulic clutches have been the norm for, oh, 30 years or more?
  6. Aug 23, 2016 at 7:05 PM
    Codycode45
    About to break 200k o got it at 100k 4 years ago and put one in it then no I don't ride the clutch I have pulled on some trees wood cutting and it got hot a couple times but not that bad it's hydraulic just seems to me it would of lasted longer
  7. Aug 23, 2016 at 9:55 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I have seen brand new clutches completely destroyed in a week a 100,000 miles is not bad.
    Do you recall just what brand
  8. Aug 25, 2016 at 12:00 AM
    eon_blue
    Azusa, CA
    100k for a clutch is about average. I've heard of them going 150k on these trucks but 100k sounds about right for a new one, especially if you tow somewhat regularly.
    Count your blessings, I had to replace my entire clutch assembly recently at 30k miles because my stupid throwout bearing went out (OEM versus supercharger, OEM lost). Performance clutches ain't cheap.
  9. Aug 28, 2016 at 11:05 AM
    Codycode45
    Its just a trd clutch its smoked i cant even give it 1/4 throttle before its spins out
  10. Aug 28, 2016 at 11:20 AM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    no, no way.
  11. Aug 28, 2016 at 11:24 AM
    WinSlow939
    WinSlow939 Road Salt Life
    Nate
    The Rock, Mass
    2002 with some '99 thrown in for fun
    All the Money I Have
    I got 160K on the OEM clutch, still going strong. I have all the parts saved in my bookmarks for when it goes, but the thing wont give up :muscleflexing: I did a couple fluid changes when I bought it 5 yrs ago, switched to Redline MT-90, then installed a URD short shifter. I baby it when I can, but tow stuff all the time and am pushing 33's...not exactly been easy on it. every truck is different, for better or worse sometimes.
    Are you planning to do the install yourself or bring it to a shop?
  12. Aug 28, 2016 at 11:25 AM
    CodeSeven
    Serge.
    Coachella Valley
    1 thing you can do though, is have your flywheel resurfaced. This will remove the polish and allow the clutch to grab better. you don't have to change the clutch, but when you do change the clutch, you need to resurface the flywheel again.
  13. Aug 28, 2016 at 2:16 PM
    Codycode45
    Im a broke ass any recommendations on price of a kit
  14. Aug 28, 2016 at 2:26 PM
    WinSlow939
    Nate
    The Rock, Mass
    I'd say your looking at $250 +/- for a decent kit. If you go cheap, you'll be doing it all over again soon enough; don't go there
    http://www.ebay.com/itm/15104669036...99&_trkparms=gh1g=I151046690367.N36.S2.R2.TR5
    If your broke, certainly don't bring it to a shop. DIY (youtube's your friend) and rent whatever special tools you'll need, or find someone close by that will hook it up for plenty of beer and some cash...
    GL
  15. Aug 28, 2016 at 5:35 PM
    Codycode45
    I was just looking at center force there shut is bad ass pricy but bad ass
  16. Aug 28, 2016 at 6:17 PM
    WinSlow939
    Nate
    The Rock, Mass
    Yah dude, every quality part made for our trucks is pretty bad ass; the crux of the matter is whether you can afford it... if not, don't waste your time, get what you need and save up for the upgrade later :thumbsup:
  17. Aug 29, 2016 at 7:21 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    As recommended a couple posts above, if you truck is basically stock, just get an OEM replacement Aisin clutch kit.
