Cly 6 Missfire - burnt valve and broken spring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Malina, Oct 15, 2019.
  1. Oct 15, 2019 at 12:37 PM
    Malina
    Malina [OP] Member
    2005 TRD Sport
    2005 DC TRD sport 4x4 with only 130k. 160lbs in all cylinders except #6, it has 60lbs. Diagnosis is a burnt valve and broken spring. Wondering how this happens and what my options are? Am I looking at a full rebuild? I just added engine restorer as a band aid until I figure out what I'm going to do with it.
  2. Oct 15, 2019 at 12:43 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    Yup, pull both heads and have them redone. Probably a sticking valve broke the spring. If you want to keep it, that's what you should do. If you're capable, pull the heads yourself and take them to a machinist that rebuilds heads and reinstall. Much cheaper.
    Good luck with it...but you can't drive that for long with a broken valve spring.
    Jeff
  3. Oct 15, 2019 at 12:50 PM
    Malina
    Malina [OP] Member
    2005 TRD Sport
    That's what I figured. Thanks for the input, Jeff.
  4. Oct 15, 2019 at 12:53 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Probably lost a valve guide which lead to stuck valve and broken spring . Time to pull the heads and have it rebuilt . Also if you want to upgrade to aftermarket cyl heads , cams and valve springs for more hp now is the time
    BassAckwards likes this.
  5. Oct 15, 2019 at 1:31 PM
    Malina
    Malina [OP] Member
    2005 TRD Sport
    Ugh, was not really in the mood to spring for a rebuild. Dangit. I thought these things were supposed to be trouble free, haha.
    Bleep100 likes this.
  6. Oct 15, 2019 at 1:37 PM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    I understand your pain, but the lower end is probably fine. As said, if you can pull the heads yourself, you'll save a whack of cash.
    Is what it is, I guess...shit breaks sometimes...
    Or...it's time for a newer one.
    Jeff
  7. Oct 15, 2019 at 2:32 PM
    Malina
    Malina [OP] Member
    2005 TRD Sport
    Yeah, it does, and never at the right time. Oh well, I may just pull them myself.
  8. Oct 15, 2019 at 2:33 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I wouldn’t drive it, hate for that valve to get stuck in the open position enough to hit the piston and now you have more issues. Ditto on what everyone else said. Good luck
  9. Oct 15, 2019 at 2:46 PM
    Muddinfun
    Muddinfun Well-Known Member
    I'm curious how the conclusion was made that it is a burnt valve and a broken spring.
    After all, you are driving a 2005.
    JC15Taco likes this.
  10. Oct 15, 2019 at 3:22 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    ^^ this..
    Have you done a leakdown test?
  11. Oct 15, 2019 at 7:48 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I'm thinking BS.
    More likely a blown head gasket in the 2005 model.
    What symptoms were you having prior that urged you to get a diagnosis other than the misfire?
    Did they pull the valve cover and see a broken spring or are they just guessing?
    I wouldn't go just by their one diagnosis. And just for information engine restorer is not going to do anything for either the broken spring or the burnt valve if it does in fact have those. You are only going to do more damage by driving it.
  12. Oct 15, 2019 at 7:53 PM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    Can't disagree with you Jimmyh....either way, the heads have to come off.
    Cheers, jeff
    Jimmyh likes this.
  13. Oct 15, 2019 at 7:56 PM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    100 psi light in one cylinder is a little telling though.
  14. Oct 16, 2019 at 9:44 AM
    Malina
    Malina [OP] Member
    2005 TRD Sport
    I trust the diagnosis, the shop doesn't even do rebuilds so they have no dog in the hunt. I think Jeff is right though, either way, heads have to come off.
    My symptoms were a misfire basically, both at start up and, it felt like, at acceleration when getting on a highway ramp. Put it on the scanner, 6 misfire, also cats. Replaced both cats, still misfired, swapped coils, stayed on 6, took it to a friends shop where they diagnosed it.
