CNC Machined 1GR-FE Exhaust Cam Gears (3° Retard)
Discussion in 'Performance and Tuning' started by JustDSM, Apr 22, 2019.
  1. Jul 6, 2019 at 10:52 AM
    #361
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Be adventurous! As long as you dont have bolts left over after you put it back together, you're good!
    TodayWasTHeDaY likes this.
  2. Jul 6, 2019 at 11:47 AM
    #362
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I had an electrical connector left over that confused me for about 15 minutes until I realized it was the ACIS and no longer used after installing the blower
  3. Jul 6, 2019 at 12:00 PM
    #363
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    155k here, after doing mine I would say it’s probably not a bad idea to be prepared. I bought the truck just shy of 150, I don’t know how it was treated before, but I’m guessing mild neglect.
    ebuyaer2002[QUOTED] likes this.
  4. Jul 6, 2019 at 12:01 PM
    #364
    DiamondW
    Kent
    Gonzales Co. TX
    I wouldn’t bother with the chain, as that’s gonna be a lot more involved, but the top tensioners you remove to get the gear in might a decent idea.
    ebuyaer2002 likes this.
  5. Jul 6, 2019 at 1:41 PM
    #365
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    190k on my truck. Engine was hydrolocked and truck spent a night under water back at 130k. Chains were in good shape here.
    BassAckwards, Torspd and ebuyaer2002 like this.
  6. Jul 6, 2019 at 6:07 PM
    #366
    ebuyaer2002
    ebuyaer2002 Well-Known Member
    Nate
    Salem, OR
    08 Tacoma TRD OR DCSB 6 Speed
    RC 6" lift, icon coilovers, DK uppers, URD intake, DT Longtube Headers, Cam gears, 70mm throttle body, Custom Tuned with HPTuners
    Oh thats not bad at all. I was expecting to have to replace it all. Don't have to worry about guides or anything? Just tensioners? I come from a 3.4 toyota and still learing the inn and outs of these. Just got mine with 136k and just at 140k now. Really looking forward to doing these gears soon, and appreciate learning along the way. 20190513_145643.jpg
    DiamondW[QUOTED] likes this.
  7. Jul 6, 2019 at 6:15 PM
    #367
    DiamondW
    Kent
    Gonzales Co. TX
    That’s the most I would consider, most probably won’t need tensioners even. I think mine was the exception, but it couldn’t hurt.
  8. Jul 6, 2019 at 6:22 PM
    #368
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Dorman?
    You just said a bad word. Apologize to the group right now for such foul language.
  9. Jul 6, 2019 at 6:25 PM
    #369
    DiamondW
    Kent
    Gonzales Co. TX
    :laugh: Lord I apologize. I figured that was a good way to show how bad it was.
  10. Jul 6, 2019 at 9:36 PM
    #370
    Blue2010
    Blue2010 Active Member
    2013 tacoma double cab sport 4x4
    Any orders coming soon?
  11. Jul 7, 2019 at 4:19 PM
    #371
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Should be a new one being placed soon. ;)
    Blue2010, PapaBear and mightytacoman like this.
  12. Jul 7, 2019 at 5:34 PM
    #372
    mightytacoman
    Kel
    4.5L 1grfe
  13. Jul 25, 2019 at 3:07 AM
    #373
    Smittyxr1984
    Smittyxr1984 Well-Known Member
    2007 XR
    Are any still available?
  14. Jul 25, 2019 at 3:29 AM
    #374
    ThomasMore66
    Dallas/Fort Worth & Durango
    Some may come available because people have now ordered cams.
    BillDaCat8 and Torspd like this.
  15. Jul 25, 2019 at 4:00 AM
    #375
    DiamondW
    Kent
    Gonzales Co. TX
  16. Jan 2, 2023 at 7:10 PM
    #376
    dnl_tacoma
    dnl_tacoma Lead the Way
    Daniel
    Stover, MO
    2013 Tacoma TRD OR 6M/T Supercharged
    Supercharged 3° retarded exhaust cam gears, URD Short Shifter, Custom Pin Shift Knob from T.W. Member (Coupe) Pop&Lock, Total Chaos Bed Stiffeners, Full Bedrug, Toytec 2.5 Boss w/resi Durobump Stops, EMP Shield Meso V2 Dome and Map & TopperEZLift Morimoto XB & 4bangers Warfab front rear & bumper Smitty x20 gen 3 10k winch
    I have a question. I just bought a Magnuson supercharger and want to do the exhaust cam gears while I'm at it. Would I need to do a custom tune or would Magnuson stock tune be fine? I talked to a shop and they said it'd void Magnuson warranty and they don't do custom tunes. The closest known tuner is a good 5-6 hrs away. Whats the skinny folks? Thanks in advance and best wishes to all.
  17. Jan 2, 2023 at 7:40 PM
    #377
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    HPTuners is the way. You can adjust for the gears with that. @JustDSM is our resident HPTuner expert here. Made me several versions of my SC tune, he's a good dude and is super helpful.
    dnl_tacoma and Torspd like this.
  18. Jan 3, 2023 at 5:31 AM
    #378
    dnl_tacoma
    Daniel
    Stover, MO
    I understand that much, but will the stock tune from Magnuson get me by till I can get it tuned or would it be dead in the water with the stock tune? Thats my question.
  19. Jan 3, 2023 at 8:17 AM
    #379
    JustDSM
    JustDSM [OP] Oderint Dum Metuant
    Justin
    Ogden, UT
    You'll be fine on the supplied tune.
    dnl_tacoma[QUOTED] likes this.
  20. Jun 12, 2023 at 2:03 AM
    #380
    MasonSTL
    MasonSTL Well-Known Member
    Green Bay, WI
    06 TRDOR AC MT
    Anyone run into starting issues after install?
    Truck is frequently taking a couple of cranks before she fires up. Once running everything is minty.
