CNC Machined 1GR-FE Exhaust Cam Gears (3° Retard)
Discussion in 'Performance and Tuning' started by JustDSM, Apr 22, 2019.
  1. Aug 28, 2024 at 1:34 PM
    #381
    Shawnrs
    Shawnrs Member
    2015 TRD Sport DCSB Manual
    Relentless Armour, Runva winch, 255/85-16 Toyo M5 Tires
    2015 trd sport manual. 255/85-16 Toyo M55. Armour.
    I am on my fourth tank of fuel. I went from an average of 400km full to yellow light, and with the last three fills, I have made it to 330km to 350km. This is not exactly what I was expecting. I'll take another tour of my engine bay to see if I missed anything. I would assume that I would have a check engine lights if there was something major.
    Other than seeming to use more fuel, there is no notable difference. I have a long road trip coming up. Hopefully, it help
    matt2491 likes this.
  2. Aug 28, 2024 at 7:19 PM
    #382
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    When is the last time that you changed your fuel filter?
  3. Aug 28, 2024 at 8:08 PM
    #383
    Shawnrs
    Shawnrs Member
    The fuel has never been changed. The timing seems a little too coincidental. I will try your suggestion.
    Thank you
    Yikes, I thought the fuel filter would be easy. It looks like I'll have to drop the fuel tank. I hope that is not the issue.
    Torspd likes this.
  4. Aug 29, 2024 at 4:34 AM
    #384
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Did you disconnect the battery during the installation, or no?
  5. Aug 29, 2024 at 5:47 AM
    #385
    Shawnrs
    Shawnrs Member
    Yes. I even disconnect the battery for oil changes.
    Torspd likes this.
