CNC Machined 1GR-FE Exhaust Cam Gears (3° Retard)
Discussion in 'Performance and Tuning' started by JustDSM, Apr 22, 2019.
  1. Jun 4, 2019 at 11:11 AM
    #161
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    For those interested in replacing the valve cover gaskets during the install, part numbers are 11213-AD010 & 11214-AD010. Can anyone chime in on the likely hood of needing them?
    decent "how to" for removing the valve covers here with some torque specs.
    http://www.toyota120.com/forum/showthread.php?p=186857
  2. Jun 4, 2019 at 11:17 AM
    #162
    JustDSM
    JustDSM [OP] Oderint Dum Metuant
    Justin
    Ogden, UT
    In the grand scheme of things, they're cheap insurance against leaks and having to yank the plenum/supercharger to address.
    Even on my relatively low mileage '15, I picked up a pair to replace my OE ones.
  3. Jun 4, 2019 at 12:27 PM
    #163
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I'll be replacing them when I open it up. Like @JustDSM said, relatively cheap to replace while your in there.
  4. Jun 4, 2019 at 3:31 PM
    #164
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Put a dab of fipg on the area where the front cover meets the head.
  5. Jun 4, 2019 at 8:10 PM
    #165
    JustDSM
    Justin
    Ogden, UT
    ***PUBLIC SERVICE ANNOUNCEMENT***
    At this time, I've been made aware (Thanks @DocME) that there might have been an error made during machining that has these gears timed to stock valve timing. I'm currently looking into the situation to see if it's a single set, or if there are a larger number of gears affected. At this time please do not install your gears. I'm going to address the the situation with the manufacturer and get any affected gears corrected.
    It's possible, that I will need all affected gears returned. Please stay tuned here for the latest news. I'll be sending PM's to everyone as I have a better handle on the issue.
    I can assure all parties that you will get what you originally bought into, but please bear with me while I correct this. My deepest and most sincere apologies for folks who've been waiting on these.
    Justin Hebert
  6. Jun 4, 2019 at 8:17 PM
    #166
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I can compare to my set in the garage if it helps
    Roostfactor and BassAckwards like this.
  7. Jun 4, 2019 at 8:18 PM
    #167
    JustDSM
    Justin
    Ogden, UT
    Please do! Text me your findings. I need to get a better grasp on what gears may be affected
  8. Jun 4, 2019 at 8:53 PM
    #168
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    This is sad
    12TRDTacoma likes this.
  9. Jun 4, 2019 at 8:53 PM
    #169
    JustDSM
    Justin
    Ogden, UT
    I'm not happy..
  10. Jun 4, 2019 at 8:54 PM
    #170
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I am really glad I haven’t installed mine yet :(
    Hoping for best out come in this situation.
    12TRDTacoma and JacksonTacoma like this.
  11. Jun 4, 2019 at 8:59 PM
    #171
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Thank you for the heads up. Was planning to install mine this weekend.
    @DocME how did u notice the difference?
  12. Jun 4, 2019 at 9:36 PM
    #172
    JustDSM
    Justin
    Ogden, UT
    "Mass PM" send to all those with gears shipped.
    To those in round 2, this should be a non-issue. Production has yet to start and corrections to procedure will be in place prior to the manufacturing those gears.
  13. Jun 5, 2019 at 6:08 AM
    #173
    mightytacoman
    Kel
    4.5L 1grfe
    I could be wrong but if you put them back to back, they align up with each other (indicated 0° retard) If they were 3° retard, this would make them 6° off on the teeth with the keys lined up. Very simple check for everyone to try. I thought that was odd several days ago when I looked them over.
    Roostfactor likes this.
  14. Jun 5, 2019 at 6:51 AM
    #174
    Wild Heart
    Wild Heart Well-Known Member
    Daryn
    2015 DCLB BRM
    I put mine back to back with a URD one that I have & they seem to be a little off. Not for sure though cause they don’t seem to stay together like they do when I put the URD ones back to back. I’m at work now & will try looking at it closer. This morning I was rushing myself.
    12TRDTacoma, DocME and Roostfactor like this.
  15. Jun 5, 2019 at 7:01 AM
    #175
    ckrockets
    ckrockets i don't own a couch
    Kalispell, MT
    2010 Tacoma 4X4 TRD sport DCB short bed
    If they are ISO 9001 Certified, and it's current, as the contracted customer you should write them a CAR/SCAR. That will get their attention quick like. If they comply, as they should, you will get Root Cause and Corrective Action as part of the response.
  16. Jun 5, 2019 at 7:52 AM
    #176
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Those ISO guys don’t mess around.
    TacoGoonin and 12TRDTacoma like this.
  17. Jun 5, 2019 at 8:23 AM
    #177
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    i also have a stock set at home i can compare mine to tonight..
  18. Jun 5, 2019 at 9:22 AM
    #178
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Hey Broski, can you send me a picture of the URD one from directly above? I want to superimpose an angle on them. I really don't want to pull mine to do this.
  19. Jun 5, 2019 at 9:30 AM
    #179
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I think anyone with 80K and over should be replacing them without question. Mine have near 110K on them and are not leaking but when I pull mine to do these I will definitely be doing them because the last thing I want to do is double work just because I end up getting leaks shortly after. If there is one thing I could never stand it is oil leaks.
    GT7 likes this.
  20. Jun 5, 2019 at 9:32 AM
    #180
    DocME
    California
    '07 FJ Cruiser
    Yes, they are the worst! Surprisingly, my 1grfe's have never leaked. I always buy oem seals where ever possible.
    12TRDTacoma[QUOTED] likes this.
