CNC Plasma Table Build
Discussion in 'Other Builds' started by Pyrotech, Nov 29, 2021.
  1. Aug 11, 2024 at 9:53 AM
    #301
    Pyrotech
    Pyrotech [OP] Well-Known Member
    It's a beefy one for sure....
    The 1/4" angle has really helped with heat absorption, along with the stitch welding and keeping a wet towel nearby to help keep things cool. I will need to flip this over and weld some supports underneath.
    Kwikvette and koditten like this.
  2. Aug 11, 2024 at 10:58 AM
    #302
    Kwikvette
    Fresno County
    4 run, 2 don't
    That's a nice decent size!
  3. Aug 11, 2024 at 11:09 AM
    #303
    Pyrotech
    55"x 55"
  4. Aug 11, 2024 at 11:12 AM
    #304
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yep I recall!
    Initially you were at what, 50" x 50" as I mentioned how STV offers a wider than published cut envelope to allow for standard sheet sizes, not to mention edge-start on thick material.
    If I knew the appropriate parts to purchase in terms of ballscrews, etc I'd love to make my current table larger.
    At least 4' x 4'.
    But I'm too lazy to do all that right now.
  5. Aug 24, 2024 at 5:12 PM
    #305
    Pyrotech
    It is finally time to put this table to use and make something useful.
    @Kwikvette posted a 5lb propane tank holder he made, I like the design so search around to see what was out there an I found the files for same 5LB propane tank holder online.
    I had recently picked up the and It made short work of removing the old coating on the salvaged 12g Mild Steel
    Bends where made on the the SWAG press brake and took a a bit of tweaking the bends to everything to fit.
    All welded up and a coat of primer.
    I need to buy some clamps to hold the bottle in place.
    Zebinator, Kwikvette and koditten like this.
  6. Aug 24, 2024 at 5:13 PM
    #306
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Awesome! Feels great doesn't it?
    Kwikvette likes this.
  7. Aug 24, 2024 at 5:15 PM
    #307
    Pyrotech
    hell yea it does...
    Kwikvette and koditten[QUOTED] like this.
  8. Aug 24, 2024 at 9:17 PM
    #308
    Kwikvette
    Fresno County
    4 run, 2 don't
    Dude, I'm glad to see the table doing well for you now.
    It's the best feeling when you run that program and everything cuts exactly as you expect it to.
    Small tip on the lead in, for outside cuts (the last one) I generally like to use a lead in distance equivalent to that of the metal's thickness.
  9. Aug 26, 2024 at 2:54 PM
    #309
    Pyrotech
  10. Aug 26, 2024 at 3:07 PM
    #310
    Kwikvette
    Fresno County
    4 run, 2 don't
    Zebinator likes this.
  11. Aug 30, 2024 at 3:24 PM
    #311
    Pyrotech
    Since I am getting closer to having a watertable, I picked up an oil filter to cut open for the silicon check valve
    It is the perfect size for a cheap Splash guard.
    the idea came from a thread on plasmaspider.com
    I also received part of the new air filtration setup.
  12. Aug 30, 2024 at 3:25 PM
    #312
    Kwikvette
    Fresno County
    4 run, 2 don't
    Good shit on the motor guard!
    But highly recommend against that funnel; I used it for a week or so and hated it (so did my consumables)
  13. Aug 30, 2024 at 3:28 PM
    #313
    Pyrotech
    good to know... least it was cheap
    Kwikvette[QUOTED] likes this.
  14. Aug 30, 2024 at 3:32 PM
    #314
    Kwikvette
    Fresno County
    4 run, 2 don't
    Probably cheaper than the 2 or 3 pack of silicone funnels I bought on Amazon
    I gave it a try and found the water that splashed up collect right on my consumables, especially when the torch was running post flow but panning over to the next cut path
  15. Aug 31, 2024 at 9:04 AM
    #315
    Pyrotech
    The water table is in place, once I got it spun in the right direction, it dropped right into place.
    Now to wait for the flex seal to dry and cure before testing for water leaks :fingerscrossed:
    Once I get the slat holders and slats cut, the major fabrication should be over.
  16. Sep 3, 2024 at 2:15 PM
    #316
    Pyrotech
    look what showed up today...
    This is very well made for the price, just wish it had some instructions on adjusting the sensors. But after seeing it in person I have a pretty good idea on how I will go about doing it.
    The 3"x3"x1/4" Aluminum angle I ordered to make the bracket that will hold the air slide came in as well. the air slide is what will move the airscribe up and down. I wanted to make sure that both the torch mount and air slide bracket get drilled an tapped at the same time. keeps me from having to remove the Z axis plate more than needed
    koditten and Kwikvette like this.
  17. Sep 3, 2024 at 2:19 PM
    #317
    Kwikvette
    Fresno County
    4 run, 2 don't
    That's crazy nice
  18. Sep 3, 2024 at 2:36 PM
    #318
    koditten
    Kirk
    Central Michigan
    Exciting times!
  19. Sep 3, 2024 at 2:49 PM
    #319
    Pyrotech
    koditten likes this.
  20. Sep 3, 2024 at 2:55 PM
    #320
    koditten
    Kirk
    Central Michigan
    Pyrotech[QUOTED][OP] likes this.
