Co2 On Board Air systems from Instant Air Supply!
Discussion in 'Automotive Group Buys' started by InstantAirSupply, Jan 14, 2015.
  1. Feb 3, 2015 at 8:27 AM
    #121
    InstantAirSupply
    InstantAirSupply [OP] Nate the Co2 guy Vendor
    Nathan
    Fresno CA
    2002 Jeep Wrangler!
    All Jeep stuff.... haha!
    Yup!
    Pm replied too.... thanks!
  2. Feb 3, 2015 at 9:56 AM
    #122
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Candy Orange 10lb with all the above Ordered :cheers:
  3. Feb 3, 2015 at 10:32 AM
    #123
    InstantAirSupply
    Nathan
    Fresno CA
    2002 Jeep Wrangler!
    Thanks man!
    Nate
  4. Feb 3, 2015 at 10:35 AM
    #124
    Manwithoutaplan
    ID
    Just wondering how heavy is the bottle when fill up?
    Sorry for what bottle
    15 pound bottle.
  5. Feb 3, 2015 at 10:40 AM
    #125
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    My guess is about 30-35LBS for the 10 pound bottle.
  6. Feb 3, 2015 at 10:41 AM
    #126
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Empty it weighs 14.8 lbs (#on bottle) then add 10lbs of co2 and it weighs right around 25lbs
  7. Feb 3, 2015 at 10:43 AM
    #127
    Manwithoutaplan
    ID
    My other question is what is the life of bottle?
  8. Feb 3, 2015 at 10:56 AM
    #128
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They need to be re certified every 5 years (IIRC). Otherwise, if you take care of them, they'll last a long time.
  9. Feb 3, 2015 at 11:16 AM
    #129
    InstantAirSupply
    Nathan
    Fresno CA
    2002 Jeep Wrangler!
    Full 15lb is around 35lbs. And the other guys answered the other questions accurately! Thanks guys!
  10. Feb 3, 2015 at 1:58 PM
    #130
    4x4Banger
    4x4Banger Gold Member
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    How much does it cost and where would you go to get them re certificated?
  11. Feb 3, 2015 at 2:01 PM
    #131
    4x4Banger
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    Also curious how much heat can they take? Would it be ok to mount in cab with the summer heat/would it be fine sitting in the summer sun no air flow?
  12. Feb 3, 2015 at 2:13 PM
    #132
    InstantAirSupply
    Nathan
    Fresno CA
    2002 Jeep Wrangler!
    Runs around $30, and any welding supply shop would be able to either test, or refer you to a place for hydro-testing.
    It's NOT ok to mount inside the cab with the windows up, during the summer if it's very hot outside +100F. The tank has a safety valve that would pop and expel the contents of the tank if pressure got to high, this however is NOT something you want to have happen. If that valve popped in an enclosed space that you happen to be occupying you could suffocate!
    Now having said that, of all compressed gas cylinders Co2 is the safest to carry around. It's stored at much lower pressure and has a much higher safety margin with heat. You just have to use a little common sense if you live in a very hot area of the country. I live in one of the hottest parts of the country, and leave my bottle in my Jeep year round, I also don't run a full top! Ventilation is the key!
    Nate
  13. Feb 3, 2015 at 3:15 PM
    #133
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just to add here, if the tank is over filled, it can blow the safety valve/disk. Its not a big deal, as the place filling it can replace it quickly, but something to note. Make sure the place filling the tank isn't staffed by idiots, and if its over filled don't think its a "bonus".
  14. Feb 3, 2015 at 6:27 PM
    #134
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    Brings me back to my paintball days haha....there's alot of idiots around Tucson, stay away from sports authority!
  15. Feb 4, 2015 at 3:21 PM
    #135
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Received mine today. Will post up a pic later. I plan on getting it filled sometime next week.
    Purple really looks awesome in person!!
  16. Feb 4, 2015 at 3:38 PM
    #136
    Manwithoutaplan
    ID
  17. Feb 4, 2015 at 6:53 PM
    #137
    JdevTac
    Josh
    MD/GA
    2nd gen
    Pics!
    A little bummed I found a chipped piece in the powdercoat right on the edge of the tank bottom. Not sure if that was just accidental/missed or probably done by UPS. The delivery guy sort of just dropped the box on its side at my door while he was busy yapping to his buddy on his damn Bluetooth headset.
    Anyways! No problem! Going to get a tank boot anyways so it will be covered up.
  18. Feb 4, 2015 at 7:34 PM
    #138
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That looks great!!
  19. Feb 4, 2015 at 8:59 PM
    #139
    InstantAirSupply
    Nathan
    Fresno CA
    2002 Jeep Wrangler!
    Uhg, that chip! I try to pad and pack them very tightly in the box to prevent anything like that! I can assure it would not have left here like that! :eek: Check your PM's....
  20. Feb 5, 2015 at 8:14 AM
    #140
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It'd pointless. it remains the same pressure until your empty
