Coastal Offroad Talky Time
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UnderfundedTaco, Oct 17, 2019.
  1. Jul 26, 2022 at 7:53 AM
    #441
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    niiiiice! cant wait to see the white.
  2. Jul 26, 2022 at 7:54 AM
    #442
    KingOfTheNorth
    KingOfTheNorth Kum and Go King
    97 4runner
    All the mods
    I dont know if I got a different set to. Mine look like those but all black and allot more adjustment range it seems .
    I ended up just cutting the 2x3 and putting that on. Figured it would be more stout than the welding of the flat strap.
    Yacob_D[QUOTED] likes this.
  3. Jul 26, 2022 at 8:00 AM
    #443
    Yacob_D
    Yacob_D It's Fine, Leave It.
    Jacob
    The J
    08 Red, AC
    Couple nuts and bolts 4x converted
    They must have switch them to cut some cost?? I built mine last year in march, no matter it's time to upgrade! Appreciate the pics as well, you guys are always very helpful. Glad I can contribute as well.
    KingOfTheNorth likes this.
  4. Jul 26, 2022 at 8:02 AM
    #444
    KingOfTheNorth
    97 4runner
    All the mods
    trucks going to look all jacked up for a week or so. Pulling the front to send it to pc aswell.
    XPOTRPR[QUOTED] likes this.
  5. Jul 26, 2022 at 8:05 AM
    #445
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    worth it. I need to finish the front and send it off as well.
  6. Jul 26, 2022 at 8:06 AM
    #446
    KingOfTheNorth
    97 4runner
    All the mods
    the other two hoops for the headlights?
  7. Jul 26, 2022 at 8:10 AM
    #447
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Those and cut some holes in the wings for flush mount s2's for ditch lights. Then PC because its only paint now.
  8. Jul 26, 2022 at 8:11 AM
    #448
    KingOfTheNorth
    97 4runner
    All the mods
    Oh I like the S2 idea!
  9. Jul 26, 2022 at 8:36 AM
    #449
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    would benefit you too yeah? dont you have ditch brackets on the hood? I could never get a good angle on the passenger side due to the Airflow in the way.
  10. Jul 26, 2022 at 8:53 AM
    #450
    KingOfTheNorth
    97 4runner
    All the mods
    Yeah I do. And sports down in the bumper. All I would have to do is weld on some light brackets I have left over from the ADD days. But I have pretty good angles on those and happy with them. I need to add more light out the back. But will add those to the GFC. So will need some brackets machined for those.
  11. Sep 23, 2022 at 8:35 PM
    #451
    twhalm
    twhalm Well-Known Member
    Denver, CO
    2015 TRD/OR Manual, OME , Dual battery
    I finally just finished up installing my bumper on my 2015 and I ran into the same issue with that annoying little trim piece under the head light. I don't have the metal fab skills posted above but I did end up successfully designing and 3D printing a similar component. I can post pictures later, but if anyone is holding back on 2014 or 2015 years or is having this issue I can either send along the CAD files or print brackets for you.
    Grumpy[QUOTED] and Slashaar like this.
  12. Sep 26, 2022 at 9:41 AM
    #452
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    My trim pieces fit, but when the frame flexes it pops them out, so I just run without.
  13. Oct 11, 2022 at 10:40 AM
    #453
    twhalm
    Denver, CO
    Forgot a photo!
  14. Oct 11, 2022 at 11:54 AM
    #454
    Slashaar
    Josh
    Kansas City, MO
    You have as much trouble as me blending the tubes together? :rofl:
  15. Oct 11, 2022 at 12:18 PM
    #455
    twhalm
    Denver, CO
    For a novice welder like me those tubes were a pain!
  16. Oct 12, 2022 at 5:23 AM
    #456
    Slashaar
    Josh
    Kansas City, MO
    Me too. I probably cut them 10 times before I just stacked welds to fill the gaps.
  17. Oct 12, 2022 at 6:51 AM
    #457
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I like how you rounded the edges of the bumper. I went the other direction and did really defined edges.. probably will grind it down the next time I repaint it.
    dk_crew and Slashaar like this.
  18. Feb 3, 2023 at 5:33 PM
    #458
    xCaldazar
    xCaldazar Well-Known Member
    Los Angeles
    2018 SR5 Purple 4x4
    King shocks, Deaver rear leaf springs, Cab mount relocation, Howe TC Pump, 315/75/17, Outgear tilted rear bumper, Tune Outdoor M1 camper, Coastal Offroad Extreme Clearance front bumper & skids (aluminum), Cali raised kick out sliders, Alphaequipt carbon air intake (color matched) Clazzio leather seat covers, Sound Deadening, Dual battery
    Where am I supposed to mount the heater exchanger? I wasn't sure from the instructions. 2018 sr5 installing the extreme clearance front bumper.
    Pretty sure this heat exchanger is supposed to be on top of the new cross member. What is this a heat exchanger for? Trying to know what fluids will come out if I undo the connections to move it.
  19. Feb 4, 2023 at 8:25 PM
    #459
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    2nd gens that line runs to the radiator and is for transmission fluid.. kinda funny with what's going on there. Maybe delete the line and run a cooler and relocate to another area?
    Dye22 likes this.
  20. Feb 10, 2023 at 6:12 AM
    #460
    Slashaar
    Josh
    Kansas City, MO
    Transmission cooler. You'll lose transmission fluid if you unhook it. So prepare for that.
