Cobra 75 connect it to AUX of radio?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 67siia, Sep 22, 2018.
  1. Sep 22, 2018 at 8:56 AM
    67siia
    67siia [OP] Well-Known Member
    J
    32164
    2009 4WD DCLB aka Chupacabra
    a few weeks back I read (so I think), that you can connect the Cobra 75 external speaker wire to the AUX on the stock radio? Now, I can’t find the post... any help would be greatly appreciated.
  2. Sep 22, 2018 at 10:29 AM
    potstech
    potstech Well-Known Member
    Midlothian, Va
    2013 DCLB
    Just get the proper cable to run the audio from the PA speaker output to the input to AUX input for your radios. A mono cable should do the trick. To listen to the Cobra on the radio select the AUX. I would set the Cobra audio to no more than 1/4 until you get it tested out so not to overload the AUX input cicuit. And turn the Cobra OFF when not in use.
  3. Sep 22, 2018 at 2:07 PM
    67siia
    J
    32164
    Brilliant, thank you!!
  4. Sep 22, 2018 at 7:32 PM
    potstech
    Midlothian, Va
    2013 DCLB
    You are welcome.
