Cobra 75 WXST Installation
Discussion in 'Audio & Video' started by Tacomake, Jan 31, 2010.
  1. Jan 31, 2010 at 5:36 PM
    Tacomake
    Tacomake [OP] Member
    07 Double Cab TRD - Speedway Blue
    GATR Systems Tracking (www.gatrsystems.com) Access Limited Edition Toneau Electric Pop N Lock for Tailgate
    Finally got around to installing the Cobra 75 WXST. These things are awesome when your moving through bad weather. Here's a few pictures of the install. I mounted the unit in the center console as I had seen others do. I ran two antenna cables. One was for a window mount antenna and the other for hitch mount antenna. I really didn't want to drill any holes nor did I want a magnetic mount. The window mount I finished, but still haven't installed the antenna on the hitch mount. Has anyone done one of these?
    I know neither of these locations are optimal for RF, but its my only options at the moment. I've used it a couple times already with the window mount antenna and was pleasantly surprised by the range. The CB has power even when the key is out. I added a switch as a safeguard and because of some future additions I might make later. I used a rubber grommet and some tie wraps to mount the cable for the handheld. I'll post some pictures later of the window mount antenna and hitch mount when I'm done. Anyways here's some pictures:
  2. Jan 31, 2010 at 5:43 PM
    oofy15354
    oofy15354 Proud Tundra *****
    Dave
    Massachusetts
    Herculiner, Access Tonneau, Uniden cb, firestik antennae, Bosch Wipers, JVC Ipod headunit, Boston Acoustic Speakers
    looks damn good
  3. Jan 31, 2010 at 5:47 PM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    I agree, great job!
  4. Jan 31, 2010 at 8:27 PM
    JKD
    JKD Well-Known Member
    Quick question about taking off the 'trim' panel on the rear of the console. Does that just pop off, or do you have to remove the console to remove the panel?
  5. Jan 31, 2010 at 9:12 PM
    Tacomake
    It just pops off. I used a 4" plastic drywall taping knife to snap it out.
  6. Jul 17, 2010 at 1:00 AM
    ShaLor
    ShaLor Well-Known Member
    Shane
    Burbank, CA
    07 4x4 Doublecab TRD Off Road
    Custom mud flap removal from rock on trail :), Tailgate Hose Clamp Mod, Cobra 75 wx st CB install, 19 more D-Rings in the bed, Satoshi Grill, Fog Lamp on any time mod. Relentless Fab CB antenna hood mount, LED bed lights, Demello Hybrid Sliders, Undercover Tonneau Cover, Lighted 4x4 switch
    Nice work on that install. I am about to buy and install a Cobra myself. Where did you run the antenna wire from the bed to get it into the cab?
    By the way, what is the toggle switch for?
    MSU Taco likes this.
  7. Jul 17, 2010 at 6:29 AM
    chaztoyo
    chaztoyo Well-Known Member
    Chaz
    West TN
    10 Tacoma DCSB TRD Sport White
    Nice clean install. Looks good.
