code 0012
Discussion in 'Technical Chat' started by jinxed77, Sep 16, 2009.
  1. Sep 16, 2009 at 9:41 AM
    jinxed77
    jinxed77 [OP] Well-Known Member
    06 4.0L TRD SR5 4x4
    I'm new to the site.I'm also the unlucky owner of 06 TRD 4x4 which has been nothing but trouble so far.
    I took my truck in for it's 36,000 mile service and for a timing cover leak.The dealership also informed me something in the rear of the engine was leaking.They were not sure if it was the rear crank seal or the head.They went ahead and replaced the front crank seal,rear crank seal,re-sealed the timing cover, and replaced the no.1 head gasket.
    All was well for about three or four weeks.Now my truck is setting a 0012 code.Cam sensor bank 1 timing retarded ,or something like that.It is also having a slight surge at low speeds when cold.
    Has anyone else had this problem?Is their something they could have done?I'm not sure if I should take it back to the dealership or fix it myself.
  2. Sep 16, 2009 at 10:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes it is more than likely something they could have done. They would have needed to remove the timing belt to swap the head gasket. It is more than likely something wrong with the OCV or the filter is clogged.
  3. Sep 16, 2009 at 2:42 PM
    jinxed77
    06 4.0L TRD SR5 4x4
    What's odd is it took about three weeks to set the code.From what I've read their is supposed to be a filter on the sensor.I'm wondering if they got some gasket material or something in their to clod it.I did notice the variable valve timing isn't working right.It just does not have the pep on hills and acceleration it did.
    I'm trying to decide what's the best way to approach the service manager about it. So far they have been good to me. Hopefully they will not let me down this time.I have spoke with the service manager in the past and he seemed like a nice easy going guy.
  4. Sep 16, 2009 at 2:48 PM
    98tacoma27
    Ben
    Not Beech Creek
    That is exactly what I am thinking. If you looked at the PDF, you can see the location of the valve and filter. Personally, I would check them both before I went to the dealer but that is just me.
  5. Sep 16, 2009 at 2:48 PM
    98tacoma27
    Ben
    Not Beech Creek
    Who knows. The connector for the valve may be loose?
  6. Sep 16, 2009 at 4:25 PM
    jinxed77
    06 4.0L TRD SR5 4x4
    I found the sensor. Reads good works fine off the vehicle.Now if I can find the filter.
  7. Sep 19, 2009 at 12:38 PM
    jinxed77
    06 4.0L TRD SR5 4x4
    I dropped my truck off at the dealership for my 0012 code. Hopefully they will treat me right. They haven't let me down so far. When I find out what the issue is I will post it.
  8. Sep 24, 2009 at 11:16 AM
    98tacoma27
    Ben
    Not Beech Creek
    Update?
  9. Sep 24, 2009 at 6:06 PM
    jinxed77
    06 4.0L TRD SR5 4x4
    Yeah,I just got it back this evening.
    They replaced: 1 camshaft timing gear assembly part#13050-0P010 Warranty
    2 Gasket #90430-16007 Warranty
    1 Oil Controller Filter #15678-31010 Warranty
    The receipt says it was replaced according to TSB.I couldn't find any filter or TSB.The Toyota parts guy in Nashville also couldn't find a filter. The Service manager also said their was no filter when I explained the situation on the phone.:confused:It is driving fine and seems to be fixed.Tomorrow will tell me for sure.The code is on a two trip detection.Before it would drive fine 1 minute then usually after it warmed up or on the second trip is when it acted up.For future reference for other members the symptoms were rough idle and reduced power especially around or above 2,000 RPM.It was a struggle at freeway speeds.4cyl cars would run off and leave me.
    P.S. The surge was a one time occurrence and never happened again.
    I will post tomorrow as a final verification.
  10. Sep 24, 2009 at 6:08 PM
    98tacoma27
    Ben
    Not Beech Creek
    Great. Glad to hear.
  11. Sep 24, 2009 at 6:19 PM
    jinxed77
    06 4.0L TRD SR5 4x4
    I still can't help but wonder. Was their unnecessary worked done before with the head gasket? If it was it may have backfired on them. I still wonder was their really a TSB?Or did they just f up?If not I don't see why they would have listed it.I guess I will never really know for sure. They haven't given me any reason not to trust them yet I guess.:confused:
  12. Sep 24, 2009 at 6:25 PM
    98tacoma27
    Ben
    Not Beech Creek
    I can't locate one either?
  13. Sep 28, 2009 at 9:12 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    More than likely, the tech left a bolt loose, and damaged the sprocket, sensor, and anything else around that area. It's easier to tell you it was a TSB, than a mistake.
    I see stuff like this on a daily basis.
  14. Sep 29, 2009 at 3:14 PM
    jinxed77
    06 4.0L TRD SR5 4x4
    I wouldn't be surprised if that were the case. I did find a bolt loose on my valve cover and a hose clamp off my radiator hose. I don't see how the hose didn't blow. It's about a 30min drive from my house to the dealership. If I wanted to be a ass about it I could have just let it blow and overheat.
