Code 0420 and torque read out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gainman, Jul 2, 2012.
  1. Jul 2, 2012 at 7:28 PM
    gainman
    gainman [OP] Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    So I have been throwing code 0420 and 0430 (catalyst efficiency below thresh hold) and really hoping its not my cats. I have the torque app on my phone and the obd2 bt reader, here is the test codes that came up. Does this mean the o2 sensors might be bad? If I run the test multiple times I do not get consistent results. Bolded the parts that failed:
    Mode $06 report generated by Torque for Android
    Vehicle VIN: 5TEUU42N06Z169479
    Vehicle Manufacturer: Toyota
    Vehicle Calibration ID: 30435000
    Test report:
    MID:$01 TID:$8e
    - O2 Bank 1 Sensor 1
    Max: 19.898V Min: 0.199V
    Test result value: 0.753V
    PASS
    MID:$01 TID:$91
    Max: 3.58984mA Min: 1.5625mA
    Test result value: 2.51172mA
    PASS
    MID:$02 TID:$07
    Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
    Max: 0.214V Min: 0V
    Test result value: 0.156V
    PASS
    MID:$02 TID:$08
    Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
    Max: 1.19V Min: 0.585V
    Test result value: 0.722V
    PASS
    MID:$02 TID:$8f
    Max: 2.49826 Min: 0
    Test result value: 0.05063
    PASS
    MID:$05 TID:$8e
    - O2 Bank 2 Sensor 1
    Test result value: 0.751V
    PASS
    MID:$05 TID:$91
    Test result value: 2.51562mA
    PASS
    MID:$06 TID:$07
    Minimum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
    Max: 0.214V Min: 0V
    Test result value: 0.097V
    PASS
    MID:$06 TID:$08
    Maximum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
    Test result value: 0.742V
    PASS
    MID:$06 TID:$8f
    Max: 2.49826 Min: 0
    Test result value: 0.04819
    PASS
    MID:$10 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - O2 Bank 4 Sensor 4
    Max: 53,288 Min: 6,424
    Test result value: 56,224
    FAIL
    MID:$21 TID:$a9
    - Catalyst Monitor Bank 1
    Max: 9.99393 Min: 0.03873
    Test result value: 0.0122
    FAIL
    MID:$22 TID:$a9
    - Catalyst Monitor Bank 2
    Test result value: 0.0305
    FAIL
    MID:$01 TID:$8e
    PASS
    MID:$01 TID:$91
    PASS
    MID:$02 TID:$07
    Max: 0.214V Min: 0V
    PASS
    MID:$02 TID:$08
    PASS
    MID:$02 TID:$8f
    Max: 2.49826 Min: 0
    PASS
    MID:$05 TID:$8e
    PASS
    MID:$05 TID:$91
    PASS
    MID:$06 TID:$07
    Max: 0.214V Min: 0V
    PASS
    MID:$06 TID:$08
    PASS
    MID:$06 TID:$8f
    Max: 2.49826 Min: 0
    PASS
    MID:$10 TID:$0c
    FAIL
    MID:$21 TID:$a9
    FAIL
    MID:$22 TID:$a9
    FAIL
    End of report.
