Code and hose Help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by collector69, Apr 3, 2012.
  1. Apr 3, 2012 at 12:41 PM
    collector69
    collector69 [OP] Member
    Curt
    Lexington, MA
    2001 Tacoma
    Hello people, my check engine light is on and I need to have my 2001 Tacoma inspected by the end of April. I bought a code scanner and it seems to show different codes everyday but only 2 thank god. The latest codes are P0125 insufficient coolant temperature and P1135 Air/Fuel sensor Bank 1 Sensor 1 heater circuit malfunction. Also there is a hose not connected at one end. It originates at the plastic holder for the air filter then theres a hose connected to a metal pipe and another hose comes off that metal pipe and that is the hose not connected at the end it's just hanging please help.
  2. Apr 3, 2012 at 4:00 PM
    collector69
    Curt
    Lexington, MA
    2001 Tacoma
    Here is the picture of the hose.
  3. Apr 4, 2012 at 1:10 AM
    01TacoBuz
    01TacoBuz Well-Known Member
    In the woods
    01 Tacoma SR5
    K&N drop in filter, URD rear simulator, Deck plate mod/home made CAI, No rear cat, MagnaFlow muffler
    I would say it is your afr sensor that needs to be changed
    It is located near your front catalytic converter, you can change it out in 5 mins
    This should take care of your check engine light
  4. Apr 4, 2012 at 9:33 AM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    i'd say that hose is suppose to connect to another pipe that goes from the fuel tank to the airbox. its suppose to vent fuel vapors and send them to the airbox. at least that is my guess. and if it isn't connected that may trip a code
  5. Apr 6, 2012 at 6:35 AM
    collector69
    Curt
    Lexington, MA
    2001 Tacoma
    Thank you for all your help after a new Air/Fuel ratio sensor, oxygen sensor. coolant thermostat and ECT sensor there is no check engine light on. I had them do the inspection and hopefully no more major repairs until next year.
