Code issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bullethead25, Aug 22, 2023.
  1. Aug 22, 2023 at 2:00 AM
    Bullethead25
    Bullethead25 [OP] Member
    Troy Jacobs
    Alabama
    86 T4R & 99 Taco 2.7 prerunner
    Basic
    Did a LCE delete and still shows codes of 0125-0135-0401-0171 WTFUDGE, even new o2 sensors after new manifold, anyone else got any tips...thanks
  2. Aug 22, 2023 at 2:27 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Just what did you delete THE EGR system or the balance shafts?
    Never forget with codes it is the complete circuit. The heater had failed in the O2 sensors you removed?
    A tripped Heater circuit code most likely is the cause of the PO171 code.
    The PO401 since I never did a EGR delete I have no clue how to generate a false signal to The ECM.
    Good luck!
