code P0102
Discussion in 'Technical Chat' started by happyb, Jul 20, 2010.
  1. Aug 12, 2010 at 10:54 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I think maybe your connectors to MAF or throttle body are not seatin g right. Maybe try electric cleaner and spray on the connectors. They could be dirty
  2. Sep 26, 2017 at 9:10 PM
    hiphopper37
    hiphopper37 New Member
    Scott
    Boston Area
    2012 5 lug tacoma
    fog lights tow hitch cool air intake alpine speakers tint upgraded tires roof racks
    Any luck on this? Having the same issue. For me I think I need to replace the wiring harness in the MAFS.
  3. Jun 4, 2024 at 2:43 PM
    Aroy608
    Aroy608 Member
    Adam
    SSM Ontario Canada
    2017 TRD Sport Silver
    Forestone Destination AT2 P265/65r17 Rear Air Lift air bags
    I have the same issue. My MAF was reading below spec on the scan too so I cleaned the intake and sensor. Did work. Replaced the sensor and still have a code. The new sensor reads a little closer to spec but still under spec.
  4. Jun 4, 2024 at 2:49 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Do you have an aftermarket intake?
  5. Jun 4, 2024 at 2:56 PM
    Aroy608
    Aroy608 Member
    Adam
    SSM Ontario Canada
    Stock no vacuum leaks found.
  6. Jun 4, 2024 at 2:59 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    What is your MAF reading at hot idle? Should be right around 4 grams per second (g/s).
  7. Jun 4, 2024 at 3:20 PM
    Aroy608
    Aroy608 Member
    Adam
    SSM Ontario Canada
    It is 3.8-4.5. It's about 11 at 2000 rpm when it should be over 13 and that with the new MAF. The old was read 10
  8. Jun 4, 2024 at 3:30 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I can grab a "known good" 2k RPM reading off mine in a bit but readings off idle aren't all that useful as they can vary greatly and there isn't really a specified "good value".
    The 2 best tests for MAF sensor accuracy is the idle reading and then what's known as a VE test.
    The VE test is basically a WOT pull through 1st gear while recording Peak MAF, Peak RPM, IAT, and Barometric pressure then entering them in the calculator below.
    https://atgtraining.com/atg-volumetric-efficiency-calculator/
  9. Jun 4, 2024 at 3:35 PM
    Aroy608
    Aroy608 Member
    Adam
    SSM Ontario Canada
    While driving or in Park/Neutral?
  10. Jun 4, 2024 at 3:48 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The VE test is a driving test.
    Another calculator with instructions.
    https://otctools.com/ve
    Mine is reading 3.8-4 g/s @ 700RPM ac off and about 11 @ 2000 RPM.
  11. Jun 18, 2024 at 7:46 AM
    Aroy608
    Aroy608 Member
    Adam
    SSM Ontario Canada
    Everything looks good still have a code with no engine light. Truck runs mint still hesitates on hard take off. No lack of power no problem shifting or Hwy driving.
