Code P0125
Discussion in 'General Tacoma Talk' started by cr500taco, Aug 28, 2023.
  1. Aug 28, 2023 at 9:22 AM
    cr500taco
    cr500taco [OP] Well-Known Member
    D
    Northridge
    4WD
    My '97 3.4L has been throwing the code P0125. It's been doing it, since the last time I topped off the coolant, due to my heater control valve leaking. I've been trying to chase it down. Since, it stated throwing the code, I replaced the heater control valve, made sure the system was bled, switched out the coolant temp sensor and replaced the connector and for the sensor. The connector was broken and I was hoping that was the problem. But the code is tripping. The only other thing I can think of left to do is swap out the T-stat. Any ideas of what else I can try, before I give up and take it to my mechanic?
  2. Aug 28, 2023 at 7:57 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The code description for P0125 is very misleading, it actually has to do with the O2 sensor not producing a signal when it should.
    Bivouac likes this.
  3. Aug 29, 2023 at 5:36 AM
    cr500taco
    D
    Northridge
    4WD
    Interesting, come to think of it I think, I read that before, somewhere. Guess I will try that. I need to smog it in a few months anyway.
  4. Sep 5, 2023 at 6:48 PM
    cr500taco
    D
    Northridge
    4WD
    Going to swap out the O2 sensor(s) this weekend. From what I've read, it seems like it's the upstream sensor that's the culprit or should I replace both?
  5. Sep 5, 2023 at 7:57 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Code is for the upstream sensor which is the main one used for fuel control, downstream one is mainly used to monitor the caytyletic converter.
    I'd just do the upstream one first and make sure that takes care of your issue.
  6. Sep 6, 2023 at 5:08 PM
    cr500taco
    D
    Northridge
    4WD
    That's what I was thinking, thanks.
