Code p0172
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dammmm, Oct 14, 2019.
  1. Oct 14, 2019 at 5:23 AM
    Dammmm
    Dammmm [OP] Well-Known Member
    martin
    1999 toyota tacoma v6 3.4l rwd extra cab per runner
    I switched out twice maf sensor and the o2 sensor's what next?
  2. Oct 14, 2019 at 10:22 PM
    Glamisman
    Glamisman Well-Known Member
    Assuming that this is a stock air intake system and you don't have a K & N filter that has been over oiled, or a restricted air filter.
    You are going to need to get a decent OBDII scanner capable of live data to check things. First thing I would do with a scanner is to check to see if you are running in a closed loop or open loop condition. Closed loop means that the sensors for emissions control are in control of the F.I. system, open loop means that the pre programmed settings are running things. If in closed loop I would check the engine coolant temp / temp sensor to see if she is at operating temp.. 190 ish. The sensor that shows the coolant temp for the instrument cluster is a different sensor than the sensor for the computer. If the ECT reading via the scanner shows 100 degrees and the dash gauge shows normal I would suspect a malfunctioning ECT for the computer. After that I would check fuel trims. I would suspect that the short term fuel trims would be -25% or more. If so, disconnect the line from the charcoal canister to the intake manifold, plug it and watch the fuel trims to see if they start to go positive. If they do I would suspect that the charcoal is saturated with gasoline. If there is no change, rev the motor to 2000 - 2200 rpm and watch the MAF sensor reading to see if it moves. It should.
    As you can see there is more than one thing that can cause the rich condition, I have only touched on a few of the things... you might get lucky randomly putting parts into her but more than likely not.
  3. Oct 15, 2019 at 6:20 AM
    Dammmm
    martin
    Thank you I been doing test but I like how you do it. I get on it now and get back to you. Again thank you I dont want to take it into a shop.
    cruiserguy likes this.
  4. Oct 15, 2019 at 6:39 AM
    Dammmm
    martin
    No shrift still the same and mad only went up two numbers
  5. Oct 15, 2019 at 6:40 AM
    Dammmm
    martin
    Ect 185
  6. Oct 15, 2019 at 6:56 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    A rich code is more rare than a lean code. My thoughts would be a dirty MAF, failing o2, or incorrect o2 sensor part number. They used 2 different kinds over the years- a wideband and narrowband. Or fuel injector(s) stuck partially open. Try a real strong round of injector cleaner.
  7. Oct 15, 2019 at 7:31 PM
    Dammmm
    martin
    I got that royal purple cleaner I took ti a shop today
