Code P0300; P0302 & P0303
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rod-H, Apr 26, 2023.
  1. Apr 26, 2023 at 7:28 PM
    Rod-H
    Rod-H [OP] Member
    Rod
    2012 Tacoma Double Cab 4wd
    3 inch Lift
    Truck started misfiring on the way home from work today. Initial code scan was P0300- multiple cylinder misfires. I had a set of new coil pack and a new set of plugs. I replaced all 6 cylinders. Ran the truck cleared the codes and now it is misfiring and throwing codes P0302 and P0303.
    Any thoughts?
  2. Apr 26, 2023 at 7:32 PM
    Bishop84
    Bishop84 Well-Known Member
    If its all of a sudden I'd suspect fuel.
    Any smoke? Check fluid levels?
    PzTank likes this.
  3. Apr 26, 2023 at 7:34 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Everything seated?
    Check the wires going to 2 and 3?
    Swap the coils from other cylinders to 2 and 3 and see what you have :notsure:
  4. Apr 27, 2023 at 5:23 AM
    Rod-H
    Rod-H [OP] Member
    Rod
    3 inch Lift
    No smoke, fluids are all good. Could be fuel related, but it feels just like a coil going out i.e. lumpy idle, misfire on acceleration, won't go above 50mph up hills, just bogs when getting above 3k rpm.
    I'll try switching 2 and 3 around.
  5. Apr 29, 2023 at 7:18 AM
    Rod-H
    Rod-H [OP] Member
    Rod
    3 inch Lift
    Figured it out. 2 coils died together (a little weird). One of the new coils was bad (the one I put in cylinder 3), tested in cylinder 5 (yep, bad). Additionally, some fool (me) managed to compress the electrode on one of the new plugs while installing it. That led to the misfire on cylinder 2. After putting one of the old good coils in cylinder 3 and a re-gapped plug in 2 we are back on the road.
    Thanks for the suggestions, guys.
    Another Note: Using Denso 20KR-U11 plugs, but, I looking at the cross reference on the Denso webpage I found that the Denso IK20TT is listed as the equivalent in an Iridium plug.
    According to Denso 20KR-U11 = IK20TT Iridium
    Can anyone confirm using the IK20TT?
    Rod
  6. Apr 29, 2023 at 1:17 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    They are not the same plug.
    The 20KR-U11 is a standard Nickel core plug.
    The IK20TT is an Iridium core plug.
    Both are compatible to use in the 4.0 engine.
    If your engine is running fine with the Iridium’s that’s good.
    The factory installs nickel core.
