Code P11EC - Sent to machine shop - Now new problem!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Disco, Aug 9, 2021.
  1. Aug 9, 2021 at 4:46 PM
    Disco
    Disco [OP] Well-Known Member
    Diego
    San Diego
    2018 TRD Offroad 4x4 DCSB Cement
    So back in May my truck (2018 OR 4x4) with 35000 miles got a check engine light, which turned out to be the P11EC code. The Toyota Service Center told me they had to replace the head, which meant pulling the engine. I got my truck 3 weeks later and was told that the replacement head was on backorder, so they sent the head to a machine shop. I was just happy to have my truck back for a road trip we had planned.
    This weekend the check engine light is back on! Brought it in and was told that they have to replace the 02 sensor, and that its NOT covered under warranty. They said that since it was in for a major service recently, they will pay for the part but I have to pay $350 for the service.
    This just doesn't seem right, I am skeptical that this issue is completely unrelated to them pulling my engine.
    Also it concerns me that my cylinder head was sent to a machine shop rather than being replaced with a new part. I was not even given the option for waiting on the part. I would have chosen to have my truck as it came from the factory, not machined. I personally would not want to buy a truck that has been machined to be fixed, and I think others would feel the same once I decide to sell it.
    What do you guys think?
  2. Aug 9, 2021 at 4:56 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I hate to say it, but even the quality of machine shops these days is in the toilet. I sent a BMW head out and got it back with the valve stems all at different heights a few years ago. I should have rejected it. There was no reason for them to grind the valve stem heights.
    When I installed it, it rattled like a tractor no matter how much the valves were adjusted in spec.
  3. Aug 9, 2021 at 4:57 PM
    doorsidedown
    doorsidedown Well-Known Member
    if they’re not going to warranty it, grab an OE part and throw it in there yourself. Sorry for your troubles OP, that’s frustrating.
    GarlicFarts likes this.
  4. Aug 9, 2021 at 5:06 PM
    Trail Limo
    Trail Limo Well-Known Member
    What did they have to machine?
  5. Aug 9, 2021 at 5:10 PM
    Disco
    Diego
    San Diego
    Apparently the exhaust valve on cyl 1 was not fully closing. Not exactly sure what they machined on the head
  6. Aug 9, 2021 at 7:02 PM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    What code came up when the check engine light came on?
  7. Aug 9, 2021 at 7:42 PM
    Disco
    Diego
    San Diego
    I dont know the code that came up for the 02 sensor issue.
  8. Aug 9, 2021 at 7:48 PM
    Itchyfeet
    I always thought o2 sensors fell under the emissions warranty
    Silentshredr likes this.
  9. Aug 9, 2021 at 8:03 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Imo, O2 sensors shouldn't die in 5 years.
  10. Aug 9, 2021 at 8:03 PM
    Aqualoon
    Aqualoon More stickers!
    Minnesota
    2019 Off-Road DCSB Cavalry Blue
    When I had my engine replaced last year under warranty (Jeep, not my Tacoma) they had to replace the 02 sensor with it.
  11. Aug 9, 2021 at 8:13 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    If that’s the case, they likely ’lapped’ the valve (if valve was damaged, replaced) they may have also shaved the head to ensure no warp/flat. Not rocket science and surprised nobody at the dealership knew how to do that. Might not have even have needed to pull the engine to do it (depends on side and clearance).
  12. Aug 9, 2021 at 11:21 PM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    I wouldn't loose sleep over running a head which had been Machined by an outside source; I've done it with other vehicles with no problems. For a lot of older vehicles a Machine Shop is your only option.
    That said, quality varies a lot. However I doubt a Dealership would want to risk a come-back over a poor Valve Job. You should have asked which shop they sent the Head to then researched it on your own to see what sort of work they do.
    NoOne likes this.
  13. Aug 10, 2021 at 3:48 AM
    mattm55
    mattm55 Well-Known Member
    Mid-Hudson Valley, NY
    2017 BBPearl Tacoma TRD Sport Access/AT w/SnoWay
    I worked in a machine shop that serviced a few dealers in our area. I'm on the side of the fence that the machine shop is fine provided the machine shop knows what they are doing??? Many do or they wouldn't be in business long. Some don't. Some would shortcut it and just focus on the cylinder with the issue. Hard to be 100% sure...
    Our process was to >
    Heads:
    • disassemble and clean
    • check for cracks
    • check for straightness and mill if necessary
    • check guides, valves, seats, springs retainers, etc.. replace as necessary (no knurling of guides!)
    • grind seats, resurface valves, replace as necessary (
    • reassemble with new seals as necessary
    "Apparently the exhaust valve on cyl 1 was not fully closing. Not exactly sure what they machined on the head"
    This probably damaged the seat, valve, and guide (exhaust valve can't dissipate heat and can damage valve and seat (beyond grind-ability).
    If you can do it, change the O2 yourself. I'm sure someone here has done it with guide and possible tool needed. If not, maybe go in and ask those questions on why it went bad so early, right after major engine work, etc... nicely. Not accusing. They might help out.
    Kev250R likes this.
  14. Aug 10, 2021 at 4:01 AM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
  15. Aug 10, 2021 at 6:21 AM
    Exfordman
    Exfordman Well-Known Member
    Norman
    2021 Tacoma TRD OR 4X4 LB White
    None
    I diagnosed countless Fords that came back after an engine repair with a check engine light. Many needed an oxygen sensor. I suspected many died due to use of impact guns hammering exhaust pipes bolts on and off. Something to consider.
    Kev250R likes this.
