Code reader suggestions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Truky!, Jul 29, 2021.
  1. Jul 29, 2021 at 3:22 PM
    Truky!
    Truky! [OP] Well-Known Member
    Satellite Beach FL
    2021 TRD Offroad
    Looking to get a code reader to help keep an eye on things, and clear codes if they are irrelevant. My wife has a 2021 4Runner, is there one that can I can use on both?
    I dont have any knowledge as far as a code reader goes, so simplicity is a factor too....
  2. Jul 29, 2021 at 3:34 PM
    dagobert
    dagobert Well-Known Member
    I have the Foxwell NT510, works for everything I need and intuitive to use.
  3. Jul 29, 2021 at 4:23 PM
    gForceDude
    gForceDude Well-Known Member
    I got this one:
    https://www.amazon.com/dp/B06ZYTDKP3?_encoding=UTF8
    It currently has a 40% off coupon, and that's a steal for a good product.
    I keep mine in my glove box for convenience - it is that small.
  4. Jul 29, 2021 at 4:27 PM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Dagobert,
    Are those Vehicle Manufacturer specific, I see 510 for BMW, and another for Honda Acura..
  5. Jul 29, 2021 at 4:38 PM
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    Do you have an android phone? If so, I use a cheap eBay Bluetooth scanner. I think I paid like 3 bucks for it maybe 4 or 5 years ago, so prices may vary. But you can run Torque on your phone (if you have an android) and connect via Bluetooth. It does WAY more than just read and clear codes as well. If you have an iPhone, you can still use the Bluetooth dongle, you'll just have to find a compatible app in the apple app store that works with them...sorry, I can't help much in that department though. I do know it can be done, just don't know which apps work(you might have to spend money with trial and error on some different apps, which I would never do...but still, it's an option)
    This is an example, but for some reason, mine was significantly cheaper than the listings I can find. But still, 7 bucks? that's still cheap as hell!
    https://www.ebay.com/itm/164666822394
  6. Jul 29, 2021 at 4:40 PM
    mhornco
    mhornco Well-Known Member
    I use an Innova. One that has both ABS and SRS readability. It is universal on all vehicles
    bulalo likes this.
  7. Jul 29, 2021 at 4:40 PM
    Murd3rd
    any OBDII scanner should work on ANY vehicle sold in the US since 1996 (some earlier, like the tacoma came out in the middle of 95 as OBDII). It's a government-regulated standard...
  8. Jul 29, 2021 at 5:38 PM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Yep Android all the way, thanks
    Murd3rd[QUOTED] likes this.
  9. Jul 29, 2021 at 5:42 PM
    ralphq17
    ralphq17 Well-Known Member
    Ralph
    2020 Tacoma TRD Pro - AT - Midnight Gray Mettalic
    working on it!
    I spent ~$200 on an Innova that does ABS & SRS and it has totally paid for itself multiple times.
    bulalo likes this.
  10. Jan 28, 2022 at 12:26 AM
    DeanBranson
    DeanBranson New Member
    Dean
  11. Jan 28, 2022 at 12:53 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    like others have suggested, an obd2 dongle and a phone or laptop etc is most flexible.
    you can find either bluetooth, wifi or wired USB versions on ebay...very cheap. (i prefer wifi)
    then there are free apps for both iphone and android but they tend to be limited.
    for just a few bucks you can buy an app. toyota uses a pretty common protocol so you don't have to worry, they will all support it.
    make sure the app you choose supports the bluetooth/wifi/wired type of dongle.
    these dongles are very cheap because they are chinese knockoffs of original dongles...but that was many years ago...and it is common
    to use the cheapies...they work just fine.
    you'll be able to data log and see beautiful realtime graphs and displays with most apps.
    and of course read codes and clear them etc.
    i believe torque and fusion are the most popular apps for their respective phone platforms.
    probably the best place to start would be to look up one of the apps and see what they can do
    and then decide on a compatible dongle.
    just an all in one reader does not come close to the functionality and economy of a dongle/app.
    the apps are easy to use too...very user friendly. mount your phone on dash and display all kinds of stuff and impress your friends :) for just a few bucks. (more like <$20 total)
    edit: if you want to dig into ABS etc then you will likely have to look carefully at functionality but it does not
    sound like you are interested in such and it will cost $$$. i have never had to use that depth of functionality.
    I once diagnosed (after poor running and thrown codes) a sticking injector (not on a toyota) just using data displays of a dongle/app. required some reading to understand it all
    but the codes and accompanying realtime data were there. I recall using mostly short/long term bank fuel trims, O2 sensor and MAF data among others.
    Recreationally i liked watching various temp, pressure, voltage sensors but my fav was gear number on AT.:)
    just fyi concerning my experience with this stuff. hope it helps.
    Edit2: if you do go the dongle route, consider an OBD2 extension cable with a switch in it. the port is hot when key in and it is nice not to have to plug the dongle in and out.
    be sure to remove dongle at vehicle check stations and repair/dealer shops. they will all want access to the obd2 port.
  12. Jan 28, 2022 at 2:41 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    You can get one branded for a certain manufacturer that’ll do more with that make. But the scan function works with anything. Reads codes. Tells you anything you want to know about the engine. Timing, psi, sensor readings.
