Code solved but MPG trashed?!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scoobarooo, Sep 15, 2015.
  1. Sep 15, 2015 at 1:01 PM
    Scoobarooo
    Scoobarooo [OP] Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    I had code P0401 popping a light on my truck for quite some time so I took it to the family mechanic after a month or two of finding no solutions. The code was because of a bad EGR cylanoid and bad EGR modulator.
    I told him to go on with it and replace the parts. I've gone almost a thousand miles on the new parts now and no code has popped up so that's solved now.
    BUT The reason I pushed to get it solved is because my MPG used to be 18 and then it 14 before replacing the parts.
    Today I checked my MPG and I'm done to 12.8 MPG. Does anyone have any clue at all what I should check next?
  2. Sep 15, 2015 at 5:52 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    That's pretty poor. I haven't had that code, but was able to up my mpgs by replacing the downstream o2 sensor and charcoal canister. There is a post about it on here. It may have nothing to do with your issue though.
    Are you running a 4 or 6 banger?
  3. Sep 15, 2015 at 6:14 PM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    I'm running a 4 banger. I've replaced my O2 a year ago
  4. Sep 15, 2015 at 7:25 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    Get a scanner and watch your fuel trims.
