codes 2441/2445; air switcching valve
Discussion in '2nd Gen. Tacomas (2005-2015)' started by some zilch, Apr 8, 2013.
  1. Apr 8, 2013 at 3:24 AM
    some zilch
    some zilch [OP] New Member
    ny
    08 taco base 4x4
    my truck (08, 4cyl, 5spd, base model, completely stock) has been throwing these codes. '
    2441-air switching valve stuck closed
    2445-air pump stuck off
    they are both related to some pump that injects air into the exhaust when the engine is cold to lessen emissions--completely unnecessary for truck operation and has no effect on driveability. But....i need the truck to pass inspection and it will not b/c the light is on.
    anyhow; does one of those issues "make" the other issue appear-- such as the "the switching valve stuck closed forces the pump to be off"?
    all hoses/wires are hooked up, both issues appeared at the same time. the pump costs over $900, and the valve costs $300ish. i hate to "throw parts' at the problem, but i am not familiar with this system.
    anyone have any insight?
  2. Apr 8, 2013 at 5:18 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Check on Tundrasolutions. New 5.7 has similiar problems and these guys have ways fixing on cheap.
    I would say try cleaning it up first. if that does not work than replacement.
  3. Apr 8, 2013 at 6:02 AM
    pjchrisrvm
    pjchrisrvm Member
    PA
    13 TRD Off Road DC
    First thing to do is remove your air switching valve and see if you have rodent damage. I get a lot of trucks that have acorns or other rodent debris stuck in the valve.
  4. Apr 9, 2013 at 3:31 AM
    some zilch
    ny
    08 taco base 4x4
    i briefly saw some this mentioned elsewhere, but did not realize the systems were similar...thanks
    sounds goood, i will take it out this weekend
