Codes p0440 and P0446. Fixing
Discussion in '1st Gen. Tacomas (1995-2004)' started by sramirez1516, Feb 9, 2017.
  1. Feb 9, 2017 at 12:51 PM
    sramirez1516
    sramirez1516 [OP] Saul R.
    Saul
    2002 Toyota tacoma xtracab prerunner 2.7
    None
    So 3 weeks ago my Taco CEL went off.
    Hooked my scan tool and it read P0440 and P0446. I read a bunch of threads everywhere about it. Some sugge said VSV valves which the most expensive one costs 190.00. I replaced then, erased the codes and after 3 miles the CEL went off again. I was pissed.
    I tested everything and checked and replaced cracked hoses. Erased codes and CEL went off again yesterday.
    After some serious research on various threads it all came down to the charcoal canister. Or so I thought. I was looking for an old friend who is a wiz at cars. I drove to his old shop and the dude wasn't there anymore. I saw another mechanic shop and just for poops and giggles asked if he had a smoke machine. I told him all the troubleshooting I did on the VSV valves and throughout the system and that everything seemed ok. After a chat he said I could use his machine. What a cool guy. He hooked it up and what do you know. Smoke was coming out of the filler kneck and a hose that goes from the canister to the gas tank.
    Called the dealer and it all came down to 205.00 for the hose and filler kneck. Vs 510.00 for the canister.
    Moral of the story. Perform an smoke test before throwing cash at it. I was fixing to buy the charcoal canister. Close one there.
    TacomaJunkie8691 and Logger like this.
  2. Feb 9, 2017 at 1:09 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Nobody likes a leaky Taco. Glad you got it fixed! I wonder what makes them crack?
  3. Feb 13, 2017 at 9:44 AM
    bigMac28
    bigMac28 Active Member
    Anthony Castillo
    2002 Red Tacoma DblCab V6 TRD
    Window Tint, 265/75/16 Cooper ATP, MB Wheels
    My CEL came on with the same code p0440 what exactly did do as far as a smoke test?
    Also I get an odd smell after I use my truck.
  4. Feb 13, 2017 at 10:40 AM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Glad you got it fixed without the canister. I did my canister a few years ago chasing a P0446 code. It did fix it, and I had found an OEM canister on eBay for $265. Still, a big expense.
  5. Feb 13, 2017 at 2:02 PM
    sramirez1516
    Saul
    None
    Was it leaking? or was it plugged?
  6. Feb 13, 2017 at 2:06 PM
    sramirez1516
    Saul
    None
    They guy hooked the machine up and smoke started coming out of various hoses. coming out of the canister. One in particular was a hose made of plastic that goes from the gas tank to the canister. It had a big hole in it.
    bigMac28[QUOTED] likes this.
  7. Feb 14, 2017 at 12:55 AM
    ghs57
    Chops
    Catskill Mts. NY
    That's a good question. I did not smoke test it, therefore can not be sure it was leaking. What seemed clear was that the VSV on the canister was not moving. I could not find a replacement for the VSV only, so bought the whole canister.
    If I were doing the job today, I would do more testing. The service manual has the testing procedures step by step for the VSVs. I recently replaced the VSV for evap under the hood because it had stopped working and triggered the cel. All good now.
  8. Jan 18, 2019 at 9:34 AM
    chiefO
    chiefO Well-Known Member
    Fresno, CA
    2005 Tacoma 4x4 Double Cab SB
    Hate to bring this thread back from the dead, but I am pulling p0440 and p0446 STILL after replacing the filler neck, gas cap, canister, and overfill valve. My mechanic did a smoke test and it looked like it was leaking from the gas cap and from the canister... I checked my vsv and it worked when i hooked it up to a 9V battery. What else is there that I can do to get rid of these stupid codes? Also i am getting worse milage than i usually do... if that means anything...
    Maectoy and ThunderOne like this.
  9. Jan 18, 2019 at 10:52 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Did you use OEM parts? If those parts are still failing smoke test then... you're gonna keep getting those codes.
  10. Jan 18, 2019 at 11:01 AM
    chiefO
    Fresno, CA
  11. Jan 18, 2019 at 12:09 PM
    bigMac28
    Anthony Castillo
    Do you have cruise control?
  12. Jan 18, 2019 at 12:11 PM
    chiefO
    Fresno, CA
    Yea?
  13. Jan 18, 2019 at 12:14 PM
    bigMac28
    Anthony Castillo
    Is it working?
    Reason I ask, is the CC works off of the vaccume lines, if there’s a leak in the hoses or any part of the systems it’ll stop working. Happened to me And that’s what led me to replace my check valve and seal.
  14. Jan 18, 2019 at 12:16 PM
    chiefO
    Fresno, CA
    Ohhh gotcha, yea its working, I just got back from a 200 mile trip and had no issues.
  15. Jan 18, 2019 at 12:22 PM
    bigMac28
    Anthony Castillo
    Ok just so I completely understand after you replaced the canister, gas cap, and check valve. Your still getting a leak from a smoke test or your just getting the codes?
    Also when you replaced the check valve did you replace the seal?
    The thing about our year is there are so many different vaccume lines it gets hard to diagnose
  16. Jan 18, 2019 at 12:27 PM
    chiefO
    Fresno, CA
    All that and the fuel filler neck. I haven't gotten it resmoked, I'm just pulling the codes.Yea I also replaced the seal and a few of the hoses that looked kinda janky.
  17. Jan 18, 2019 at 12:44 PM
    bigMac28
    Anthony Castillo
    Ok I’m sure you know this but when you smoke test it start from the front under the hood and work your way back, just easier to eliminate cracked hoes that way since the canister isn’t oem double check all the hoes are conncec correctly. You can’t really say what it is until you re smoke it unfortunately.
  18. Jan 18, 2019 at 12:49 PM
    chiefO
    Fresno, CA
    Yea... I think I'm gonna take it back to my smoke guy. Do you know if you have to pinch any hoses when doing the smoke test? I was watching a video on youtube and the guy used a clamp to pinch off a hose going from the canister...
    Link to the video: https://www.youtube.com/watch?v=nxP4CuzV2EY
  19. Jan 18, 2019 at 1:15 PM
    bigMac28
    Anthony Castillo
    Ya I watch that exact video and He did that to basically to make sure smoke wasn’t escaping into the gas tank, as far as your question it’s not necessary I just disconnected the hows and held my finger over it. My hoses are old too and I didn’t want to cause a crack.
  20. Jan 18, 2019 at 1:35 PM
    chiefO
    Fresno, CA
    That makes sense. If i didn't clamp the hose, where would the smoke come out of?
