Codes p0440 and P0446. Fixing
Discussion in '1st Gen. Tacomas (1995-2004)' started by sramirez1516, Feb 9, 2017.
  1. Jun 17, 2019 at 4:20 PM
    djohn24
    djohn24 Well-Known Member
    Dennis
    Pa
    03 Double cab SR5 Tacoma 4x4
    Don't know if there is a difference on the systems 4 cylinder v.s. 6 cylinder? I have a 3.4l and from what I see, there are 3 VSV solenoids on mine. 2 under hood and one at canister behind gas tank. I checked the 2 under hood. The one on top had a good clicking sound with 9 volt battery. The one below...all I could hear was the sparking with wire touching 9 volt battery. My question is, should all VSV solenoids make the clicking sound? If so, I think I found my issue for the p0446 code. The VSV (evap) solenoid.
  2. Jun 17, 2019 at 5:11 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Yes you should hear the vsv actuate. If I remember correctly, you should be able to find a replacement. I was able to find an OEM replacement for my vsv for evap that went bad. No problem with codes since then.
    chiefO likes this.
  3. Jun 17, 2019 at 5:19 PM
    djohn24
    Dennis
    Pa
    I see them on ebay...Thank you GHS57!
  4. Aug 25, 2019 at 7:59 PM
    Maectoy
    Maectoy New Member
    1996 tacoma 4x4 extended can stick shift
    Off road bumper and lights
  5. Aug 25, 2019 at 8:01 PM
    Maectoy
    Maectoy New Member
    J have had do exactly same thing and still same problem
  6. Aug 28, 2019 at 1:44 AM
    chiefO
    chiefO Well-Known Member
    Fresno, CA
    2005 Tacoma 4x4 Double Cab SB
    Check to make sure the clamps on your hoses are tight... don't ask why Im saying that lol...
  7. Aug 28, 2019 at 4:47 AM
    Maectoy
    Maectoy New Member
  8. Aug 28, 2019 at 4:50 AM
    Maectoy
    Maectoy New Member
    I checked them, but I believe you agree with me this clámps are like you can’t tight them, unless I replace them for those little ones that have the little screw so I can tight them.
    THANKS FOR YOUR REPLY by the ways I always read you guys are very helpful
  9. Aug 28, 2019 at 1:03 PM
    chiefO
    Fresno, CA
    Yea I replaced mine with one of those screw on ones and apperently it was not clamping well... expensive fix lol
