Codes P0441, P0455, P0456 came up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by valkener, Jan 13, 2020.
  1. Jan 13, 2020 at 5:29 AM
    valkener
    valkener [OP] Member
    2009 Tacoma
    Took my Tacoma in for emissions inspection and oil change to a trusted mechanic. They said this code came on, but emissions passed anyway so registration was renewed.
    Could this be as simple as the gas cap or is this more involved? Mechanic said perhaps the canister needs to be replaced, but to check with dealership. Any advice? Also, anyone know a mechanic in PA that has dealt with these exact codes.
    Thanks!
  2. Jan 13, 2020 at 5:58 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I would start with checking to make sure the gas cap is tight or even replace it, clear the code and see if it comes back. Also check for the condition of the hoses but next item would be the canister purge valve if needed.
  3. Jan 13, 2020 at 6:45 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    10+ yr old gas cap.. replace it, clear codes, see if codes return. Cheap first step
    Use a OEM cap
    REDdawn6 likes this.
  4. Jan 13, 2020 at 9:40 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    I got an OEM cap from Amazon, was like $18
    b_r_o likes this.
  5. Jan 13, 2020 at 10:59 AM
    valkener
    2009 Tacoma
  6. Jan 13, 2020 at 11:02 AM
    valkener
    2009 Tacoma
  7. Jan 13, 2020 at 6:33 PM
    SilverFox15
    SilverFox15 Member
    Riverside
    2014 Silver Tacoma SR5 4x4
    Check out the link below.
    https://www.700r4transmissionhq.com/p0441-toyota-tacoma/
    But like b_r_o said, go with the cheap fix first. Unless you cracked the cap after dropping it a few times will cause the CEL but I would check the fuel cap O-ring too, if you see cracks on the O-Ring then that might be your problem.
  8. Jan 13, 2020 at 9:26 PM
    Tacoian
    Tacoian Well-Known Member
    Try gas cap first. Then look into other options. I’m still having trouble with mine but I think I’m a special case lll
  9. Feb 15, 2020 at 1:40 PM
    kn61408
    kn61408 Retired old fart
    western washington
    09 PreRunner DCLB sport pyrite mica
    12v always on power point mod, tailgate anti-theft, Addl bed tiedowns, flyzeye dash lights, map lites with dome lite mod, bed stiffeners, air bags, brake controller, always on fog lights,
    TnShooter likes this.
  10. Feb 17, 2020 at 2:01 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Also clean the spout of the filler neck . Just a little bit of grim will cause air to get sucked in.
