Codes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Who_Am_I, Nov 28, 2022.
  1. Nov 28, 2022 at 11:25 AM
    Who_Am_I
    Who_Am_I [OP] New Member
    Billy
    2005 speedway blue TRD off road 4x4
    So my truck started throwing codes p420 and p430 last week. I was recommended to replace both cats. Left the truck sitting for the long weekend since the holiday. Today when I started it this morning the light was on. drove for about 15mins parked it when I came back out about an hour and a half later the check engine light was off. Not sure why that would happen and now I’m not sure if replacing them is still the way to go. Could it be something else causing it to throw a code? thoughts?
  2. Nov 28, 2022 at 11:51 AM
    SpruceWillis
    SpruceWillis Active Member
    2014 Tacoma spruce mica
    When i was younger i had that code on an open header honda i was trying to get through Pennsylvania emissions. I ended up welding chunks of scrap metal in the exhaust to reduce the airflow, (increase backpressure, if you will), i would weld a piece, clear code, take for ride until readiness hit, then when code came on, i welded another piece, and kept going until it passed. it worked. idk it was a wild guess but i got it to pass and readiness to set.
    but yea that code coudl be a bunch of things, in my case its an air leak, but yoru secondary o2 could also be causing it. What kind of code scanner do you have? sometimes the MILight goes off, but the code is still stored in the ECU.
    check the exhaust and look for leaks. OBD2 codes are always correct, a lot of times its a good indcation of where to start looking though. Regardless, i wouldnt take this code seriously unless you are trying to pass emissions.
  3. Nov 28, 2022 at 3:10 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Yeah those codes typically indicate bad cats, but they could also be related to a faulty O2 sensor or the sensor wires. I'd make sure the wiring to all the O2 sensors looks good first- specifically the downstream one, then start throwing money at it.
  4. Nov 28, 2022 at 5:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Converter codes and evap codes can be finicky. They can set, get cleared and take weeks to reappear. It's because of the strategy used to monitor and detect failure. Not a perfect system
    Long story short, in my opinion, of the fuel trims are stable and there's no exhaust leaks anywhere it probably needs cats
    Any history of active misfires? Like a bad plug or coil? The raw fuel that goes down the exhaust can harm converters and make them fail prematurely
    Dm93 likes this.
  5. Nov 28, 2022 at 5:56 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I have seen converters that are marginal fail the monitor under some conditions and pass it in other conditions but yea exhaust leaks, fuel trims, and proper AFR & O2 Sensor function should be verified before condemning the converters.
    b_r_o[QUOTED] likes this.
  6. Nov 28, 2022 at 6:00 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  7. Nov 28, 2022 at 6:54 PM
    BlueT@com@4×4
    BlueT@com@4×4 Well-Known Member
    2015 TRD PRO Tacoma
    Do you try use seaform to clean it up and put some at your gas tank.
