Coffee Maker with Outlet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jcman01, Jul 26, 2016.
  1. Jul 26, 2016 at 4:28 PM
    jcman01
    jcman01 [OP] Well-Known Member
    Buck
    Colorado
    2015 Offroad, 6-manual, Blue Ribbon Metallic
    Getting ready for a camping trip. My biggest concern, believe it or not, is my morning cup of coffee. Anyone come up with a way to make coffee, or at least hot water, using the 120V outlet in the bed?
    Any true caffeine addicts will understand my plight.
  2. Jul 26, 2016 at 4:30 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
  3. Jul 26, 2016 at 4:33 PM
    2nd screen name
    2nd screen name Tacodelaplaya
    Bob
    LV/SD
    06 AC Sport Prerunner
    Front: Maxtrac, DK heim UCA, 6112 Rear: AP expos, Fox 2.5 RR DSC Fn fivestar with General reds
    1. Buy a camp kettle
    2. Bring ground coffee
    3. Pour coffee and water in kettle
    4. Put in or near fire to steep
    5. Serve, let the grounds settle, cowboy coffee
    Dont be a little b!tch about it...lol
    high n mighty and Silence9 like this.
  4. Jul 26, 2016 at 4:53 PM
    jcman01
    Buck
    Colorado
    Yeah...I live in a dry state. Starting a forest fire is a bitch, too.
    LEBM, tacomacrazy and linkgoesnowhere like this.
  5. Jul 26, 2016 at 4:59 PM
    Dgibson529
    Dgibson529 Well-Known Member
    Derek
    Westfield, MA
    NE F150s of TW FTW
    Second this. Jetboils are amazing
    DaveInDenver likes this.
  6. Jul 26, 2016 at 5:00 PM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    Exactly what I do.
  7. Jul 26, 2016 at 5:01 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
  8. Jul 26, 2016 at 5:04 PM
    Dgibson529
    Derek
    Westfield, MA
    NE F150s of TW FTW
    Aeropress is awesome I have used one on all my deployments but you still need the hot water problem solved
    Tsinajinii likes this.
  9. Jul 26, 2016 at 6:02 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    I use one of these to boil water -
    Its not as nice as a Jetboil or as efficient, but it gets the job done. I can typically have a cup of coffee ready between the time it takes me to roll outta the sleeping bag and the time I need to take a dump.
  10. Jul 26, 2016 at 6:06 PM
    BlazingTaco
    BlazingTaco ~,!,,___(•v•)___,,!,~
    Exile
    2016 Tacoma SR5 BBP DCSB 4x2
    Mall landscaping pin stripes.
  11. Jul 26, 2016 at 7:50 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    I use an old school percolator.
    Perfect coffee every time .
    I have about 3 of them , easy to find at a thrift store, no paper filter necessary.
    Some are plug-in, some are stove top.
  12. Jul 26, 2016 at 8:00 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I have an old Svea 8R that is dedicated to warming water for the French press. I actually have accumulated two of them, cool little stoves. The coffee prep setup is housed in it's own luggage and is always either in the truck or ready for quick deployment.
  13. Jul 26, 2016 at 8:34 PM
    Pigpen
    Dan
    Northwest Montana
    Put your egg shells in the coffee while it heats up. They neutralize the acidity and make it taste better.
    Skyway likes this.
  14. Jul 26, 2016 at 8:43 PM
    Skyway
    Ande'
    St.Pete
    A pinch of baking soda.... Same concept
    Especially in iced tea! Takes the bitter out
    medic2230 likes this.
  15. Jul 26, 2016 at 8:47 PM
    OldandSlow
    OldandSlow Well-Known Member
    Andrew in Austin
    Austin, TX
    2015 Tacoma Access Cab - 2.7, 5 speed, 4x4
    Not much on mods - Leer 180, TRD wheels, Mobtown sliders, rear hitch, helper springs on the rear
    If you are referring to the old Svea 123 or 123R, it has all the technological advanced features of a 1930's blow torch. It'll boil two cups of water in about 6 or 7 minutes, which includes the 1 minute prime. The one I have is dead-on reliable at 11,000 elevation and at freezing cold temps, but you know the newer propane stoves will boil the same amount of water in less than 2 minutes.
    If you have an old Optimus 8R, it uses similar technology.
    B ill y likes this.
  16. Jul 26, 2016 at 9:06 PM
    coylifut
    coylifut Well-Known Member
    tk
    portland or
    2011 TRD Sport DBC LB
    Weather Techs, Wet Okoles, cbi rear bumper with swingout
    No camp stove? I've tested a few "hot pots" with the 120 volt, but no dice. i have an ancient stove top percolator, but a stainless french press works better.
  17. Jul 26, 2016 at 11:32 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    Why not plug a coffee maker in the AC outlet like I suggested?
  18. Jul 26, 2016 at 11:42 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Caffeine pills. $5 for a bottle full of 200mg tablets at the grocery store, pop one in the morning and off you go.
    That's always my backup plan, anyway. Camp stove works well for heating up a cup of water for a spoonful of instant coffee.
    high n mighty likes this.
  19. Jul 27, 2016 at 3:00 AM
    Ex-MA Hole
    Ex-MA Hole Well-Known Member
    Mark
    Concord, NH
    17 4Runner, Previously a 15 Sport
    I use an old school percolator on a coleman stove top. In a pinch, I will tell you that the Starbucks instant coffee sleeves taste pretty good. They don't taste nearly as bad as the other instant coffees out there, nor do they taste as strong and as bitter as the other starbucks coffees at the stores. I always keep them on hand for power outages/ etc.
  20. Jul 27, 2016 at 3:26 AM
    B ill y
    B ill y Well-Known Member
    Billy
    Sarasota County, Florida
    2018 4Runner Trd OR, 1997 FZJ80,1985 FJ60
    This is cool it's just like the MSR Dragonfly multi fuel Burner. But old . Probably the original. Or were they copied from.
