cofran 15w 40 thoughts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bra, Oct 7, 2008.
  1. Oct 7, 2008 at 11:46 PM
    bra
    bra [OP] Well-Known Member
    2008 AC 4X4 TRD sport
    Badges off
    Hey guys, what d u think of this engine oil : 15W40 Cofran for diesel and gasoline too, do you think I will lose performance or other?
  2. Oct 8, 2008 at 5:45 AM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    The engineers spec'd 5W-30 for a reason. I think they know what they are doing. The only thing I use 15W-40 or 15W-50 on is an air cooled engine, i.e. Porsche 911, 930, 993 cars or diesel's that spec that weight of oil. Our engines will certainly drag down and suffer a decrease in performance especially in cooler weather.
  3. Oct 9, 2008 at 9:54 PM
    bra
    Badges off
    Sorry for the mate guys, but I would chose this oil because it is for both diesel end gasoline engine and because the temperature in my country is about 20c° and 30c° so not cold weather, but what is the best oil i need to use for maximum performance? Why this 15w40 will affect the performance?is there some good brands and bad? Thanks
  4. Oct 9, 2008 at 9:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    that oil is way too thick. a good 5w30 or a 5w20 will be fine for you more than likely.
  5. Oct 9, 2008 at 10:18 PM
    bra
    Badges off
    I have just 2000miles and 8 months haven't done yet my first oil change:eek: I dont know if I need to change it now:confused: or if i can wait for the 5000 recommended miles
  6. Oct 9, 2008 at 10:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you will be safe changing it now and getting any break in metals outta there if you want to.
  7. Oct 10, 2008 at 1:01 PM
    Jeff
    Jeff Well-Known Member
    Hopkinton,MA
    Nice 6spd,V6, very solid truck
    None currently, but I would like a better sounding exhaust and perhaps a cold air pack and some color coded step bars
    bra, you can change it at any time. However, you spent a lot of bucks buying a toyota and you have to ask, is this oil weight recommended? Probably not, check your manual.
    I don't know what cofran is but you would want to know if it exceeds that standards of the oil recommended for your truck.
    Oil recommended for diesels may have other additives in it that may not suit a gas motor. You could change your oil with the proper stuff (dino or syn) and do some research on this other brand of oil or you could ask your dealer, that would be the logical thing.
    Jeff 06, V6 SR5 4x4 6spd
  8. Oct 10, 2008 at 4:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Aside from being to thick during start up, I think it would have an advers affect on the VVT-i of the engine.
  9. Oct 16, 2008 at 12:03 AM
    bra
    Badges off
    Thank you everybody for this ton of information, I think I will go for the mobil 1 5W30 synthetic, I will see tomorrow at the shop but I hope it is not too much expensive, I hope it is the best choice I can do, just tell me, Thanks
  10. Oct 16, 2008 at 12:18 AM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    The age of the oil isn't as important as it used to be many years ago. It won't void your warranty for going over 6 months.
  11. Oct 16, 2008 at 3:07 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    mobil1 5w30 will be great for your truck....and your motor will thank you!!!:)
  12. Oct 16, 2008 at 4:44 AM
    Jeff
    Hopkinton,MA
    In the northeast Mobil 1 is currently going for$25 for a 5 quart container at Walmart, more expensive in the auto parts stores where they carry it by the quart. Have not looked at other syn oil products but dino oil is still around $12-15 for a 5 quart container.
    Taco filters about $5 at my dealer. While Mobil 1 may be expensive it is cheaper overall than if you went to a dealer .....
  13. Oct 16, 2008 at 6:44 AM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    :der:i just love these retarded posts. toyota calls for 5W-30!! it doesnt say choose what oil u like best. i can understand 0-30 even. but 15-40 ? bro come on get some sense will ya. the oil starts to thick wich is when u need the oil to be its thinest. start up causes the most wear on your engine. 15w at start up is obserde these are not 1970 muscle cars. enough with this ridiculous ideas every ones and engineer all of a sudden.:rolleyes:
  14. Oct 16, 2008 at 10:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2
  15. Oct 17, 2008 at 5:10 AM
    Jeff
    Hopkinton,MA
    Have to agree with Bowhunter, stick with Mobil 1 and a quality oil filter and try to follow the manuals recommendations for oil change intervals and with reasonable care the truck should last a long time.
    Jeff 06,V6,6spd,4x4, SR5
  16. Oct 18, 2008 at 1:57 PM
    bra
    Badges off
    Problem, I've called every shop nearby my country and they don't have 5w30 mobil 1 synthetic, I've the choice between 5w50 synthetic wolf, maximus 5w40 or 20w50, what is your thoughts?:rolleyes:
  17. Oct 18, 2008 at 2:29 PM
    Jeff
    Hopkinton,MA
    Sounds like a problem, however, perhaps you could tell us what country your in and since you bought a Toyota and there has to be a dealer some where near by that you could call and ask what the appropriate oil would be for where you are.
    Now, if some standard brands of oil are not available to you, check your manual to see what types of oil will suit your truck. I really think your local/regional dealer would advise you or you could ask other Toyota owners what they do. I hope this helps.
    Jeff,06,V6,4x4, SR5, 6spd
  18. Oct 18, 2008 at 4:11 PM
    allrsdup
    Sahuarita AZ.
    which do i suggest? none of the above.
    5W 30 there is no way that there is not a store anyplace near u that doesnt have it.
  19. Oct 19, 2008 at 1:28 AM
    bra
    Badges off
    Hello, sorry to tell you the truth but there isn't or it is very rare to find it,I've called every popular shop, and because I'm not in USA but in TAHITI :D, the toyota dealer don't sell tacoma here but only hilux, and I have imported my taco by myself i love the look. What do you think if I take the 5w40 or 5w50, whats the difference?
  20. Oct 19, 2008 at 5:23 AM
    Jeff
    Hopkinton,MA
    I would suggest to you that you email/fax Toyota and explain your situation and ask them to provide a solution or recommendation....after all Toyota has cars/trucks all over the world and under many different conditions.... Keep us updated.
    Jeff, 06,V6, SR5, 4x4, 6spd
