COHBSTEQ'S basic white girl
Discussion in '1st Gen. Builds (1995-2004)' started by Cohbsteq, Nov 11, 2013.
  1. Nov 19, 2015 at 1:59 PM
    #361
    Cohbsteq
    Cohbsteq [OP] Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
  2. Nov 19, 2015 at 2:10 PM
    #362
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    BYJOSHCOOK likes this.
  3. Nov 19, 2015 at 2:13 PM
    #363
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
  4. Nov 19, 2015 at 2:16 PM
    #364
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    The rack requires drilling. We drilled out 5 holes per side and installed plusnuts (basically a stronger version of a rivnut that flares out instead of bulges to distribute the load surface more). I mentioned to Jake that due to the weak roof, the rack is better suited for lighter duty loads.
    When drilling and installing the front holes and the middle holes were close to an interior weld or spine and are pretty strong, I would trust those areas to support a load. The rear holes though seemed to be further from any structure in the roof and are definitely the weak point.
    Do I feel totally comfortable with the rack to carry firewood, maxtrax, skis, bikes, a kayak, a pelican case, etc? Yes. Would I go bombing through the desert at high speeds through the woops with a 200 lb hardshell roof top tent mounted up there? No.
  5. Nov 19, 2015 at 2:16 PM
    #365
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    its really solid in person, you being a double cab, you could totally do something in the door jambs, similar to the thule an yakima designs, us ext. cabs dont have that luxury.
  6. Nov 19, 2015 at 2:19 PM
    #366
    zscott
    Zach
    Utah
    You could do it with tracks too. However, The tracks are installed with normal rivnuts which in my opinion are much weaker than the plusnuts I use. Since the tracks only attach in 5 -6 places anyways you are gaining any strength.
    The other problem with tracks is they don't have a ton of flex. Since there is a pretty abrupt hump on the roof where it drops from the rear to the front you would have a hard time getting the tracks to follow that contour.
  7. Nov 19, 2015 at 2:45 PM
    #367
    MatthewMay1
    Matthew
    Lone Star Republic
    Somebody on here made one that had vertical supports that sat in the channels going down the length of the roof. I can't recall who it was though
  8. Nov 19, 2015 at 2:53 PM
    #368
    zscott
    Zach
    Utah
    @Box Rocket used frontrunner's rails to make one for his DC and then somebody else mirrored his and frontrunners design and created some rails for a double cab as well. Boxrocket discussed it though in his thread and the reason that frontrunner discontinued their product and the reason it is hard for anyone to make something similar is that due to the cost of production.
    Lots of people say they would buy a rack if it were available but when it comes time to shell out $400-$600 that group of people dissipates. I would guess this is why front runner abandoned the models for the 1st gen.
  9. Nov 19, 2015 at 2:56 PM
    #369
    MatthewMay1
    Matthew
    Lone Star Republic
    Ah, yeah it was his I was thinking of
  10. Nov 19, 2015 at 3:08 PM
    #370
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    what did you have in mind??
  11. Nov 19, 2015 at 3:09 PM
    #371
    MatthewMay1
    Matthew
    Lone Star Republic
    Some type of support that ran the length of the roof to distribute the weight better
  12. Nov 19, 2015 at 3:28 PM
    #372
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    oh gotcha.
  13. Nov 19, 2015 at 3:29 PM
    #373
    MatthewMay1
    Matthew
    Lone Star Republic
    But that looks pretty difficult to build with no precision machines, soooo I may be sitting this project out for a while longer
  14. Nov 19, 2015 at 4:13 PM
    #374
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    What else you got in the works?? @MatthewMay1
  15. Nov 19, 2015 at 4:30 PM
    #375
    MatthewMay1
    Matthew
    Lone Star Republic
    Oh I have a bunch of projects lined up. I need to build the rest of my skids and want to do a shock relocation
  16. Nov 19, 2015 at 4:31 PM
    #376
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    What does the shock relocation do
  17. Nov 19, 2015 at 5:16 PM
    #377
    MatthewMay1
    Matthew
    Lone Star Republic
    better rear end flex, and give me a framework to mount an air tank to for an OBA system eventually
    Speedytech7 likes this.
  18. Nov 19, 2015 at 6:13 PM
    #378
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I'd only put some cargo up there or use it to carry kayaks and what not. So no need to remove headliner?
  19. Nov 19, 2015 at 6:18 PM
    #379
    MatthewMay1
    Matthew
    Lone Star Republic
    not with those fancy rivnuts he used
  20. Nov 19, 2015 at 7:25 PM
    #380
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Sounds like a plan, I'm contemplating the same thing. But I think I also want to change the rear leaf bushings or shackle mount to currie johnny joints or similar. That way the leaf has an easier time coming further down too.
