Coil Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZachPrerunner, Jul 15, 2015.
  1. Jul 15, 2015 at 8:36 PM
    #41
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Is that tape tab only on one coil?
    Referring to the tape at the upper left of the right side coil, marked blue yellow.
  2. Jul 15, 2015 at 8:39 PM
    #42
    ZachPrerunner
    ZachPrerunner [OP] Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Yes, the owner "thought" that was the driver side. He marked it with that, but said I should check around.
  3. Jul 15, 2015 at 8:40 PM
    #43
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Right side coil goes on driver side.
  4. Jul 15, 2015 at 8:43 PM
    #44
    ZachPrerunner
    Southeast TN
    Alright, I'll let the shop know. I may ask them if they wouldn't mind checking some resources to validate my findings. Now that I think about it, when I got my spacer installed he said he can identify coils based on some code system. I guess we will find out soon enough!
  5. Jul 15, 2015 at 8:44 PM
    #45
    T4RFTMFW
    Fuck that. Just tell them here are my coils. Let them get it right or get it wrong and then fix it on their dime. They're smart enough, and you don't need the responsibility of a guessing game.
    If it's backwards after they're installed your truck will be noticeably leaning. Then you can say, "I think you have the coils reversed."
    Let them do it.
    Justinlhc likes this.
  6. Jul 15, 2015 at 8:47 PM
    #46
    ZachPrerunner
    Southeast TN
    Haha I suppose I could do that. Least they couldn't come back on me and say that's what I told them to do. Thanks for saving me some hassle if they don't do it right. I just hope my truck will be back before the weekend if it isn't done correctly!
  7. Jul 15, 2015 at 8:48 PM
    #47
    T4RFTMFW
    30 minutes per side is all they need.
  8. Jul 15, 2015 at 8:48 PM
    #48
    ZachPrerunner
    Southeast TN
    How bad does it lean if they don't install it correctly?
  9. Jul 15, 2015 at 8:48 PM
    #49
    T4RFTMFW
    Dunno. But you'll be able to tell
  10. Jul 15, 2015 at 8:49 PM
    #50
    ZachPrerunner
    Southeast TN
    Alright, I'll cross my fingers and hope for the best. You know how shops are. They don't get in any hurry.
  11. Jul 15, 2015 at 8:50 PM
    #51
    T4RFTMFW
    You'll be okay.
    ZachPrerunner[OP] likes this.
  12. Jul 15, 2015 at 9:01 PM
    #52
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    The ones I took off my son's 2015 DCSB Sport 4x4 had the yellow/lt blue on the driver's side and darker blue/pinkish on the passenger's side. Since I have lifted 5 of my personal Tacomas, I knew they were different and marked them immediately.
  13. Jul 15, 2015 at 9:06 PM
    #53
    ZachPrerunner
    Southeast TN
    YES! Thank you, least someone has viewed the coils in the same location.
    T4RFTMFW likes this.
  14. Jul 16, 2015 at 4:24 AM
    #54
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    That's me, haha
  15. Jul 16, 2015 at 9:13 AM
    #55
    T4RFTMFW
    Is it done yet?! :popcorn:
  16. Jul 16, 2015 at 3:15 PM
    #56
    ZachPrerunner
    Southeast TN
    I dropped the truck off this afternoon around 12:30, but they didn't call me if it was complete. It'll be tomorrow sometime when they are finished. One more day :annoyed:
  17. Jul 16, 2015 at 3:17 PM
    #57
    T4RFTMFW
    Waaaaaat.
  18. Jul 17, 2015 at 12:27 PM
    #58
    ZachPrerunner
    Southeast TN
    I got them installed at the .85 setting and it is sitting nose high again! One inch block is going to go in the rear to hopefully level it out. This has been a huge headache. The shop is going to have to keep it till Monday, so they can perform the alignment.
  19. Jul 17, 2015 at 12:35 PM
    #59
    T4RFTMFW
    Interesting. Your rear is either hagged out hardcore or you got more than .85 like I did.
  20. Jul 17, 2015 at 12:35 PM
    #60
    T4RFTMFW
    Consider a 1" AAL over a block.
