Coil Isolator Repl.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kenvincent19.spruce, Nov 8, 2024.
  1. Nov 8, 2024 at 12:10 PM
    kenvincent19.spruce
    kenvincent19.spruce [OP] Member
    Ken Vincent
    2013 Spruce Mica Tacoma TRD sport DCLB
    Hi, everyone
    Any recommendation for replacement isolators? Was driving today and heard scraping then saw this... ugh
  2. Nov 8, 2024 at 6:35 PM
    Taco'09
    Taco'09 Well-Known Member
    IMHO get OEM. I have had bad luck trying to use aftermarket, including the KYB ones, which cracked severely in no time. Unfortunately the OEM are way to expensive for what they are. Maybe others will chime in with recommendations.
  3. Nov 8, 2024 at 6:53 PM
    kenvincent19.spruce
    Ken Vincent
    Would you happen to know what part number it is or where I could get the OEM ones. Yeah unfortunately these were the only ones I could find at the time. Were installed June 2023. Didn't last that long.
  4. Nov 9, 2024 at 1:43 AM
    Taco'09
    To get that OEM rubber piece from Toy you got to buy the top hat $$$ (thanks Toyota, not).
    The current part number is 48609-04020 for both right and left.
    Kolter45 likes this.
  5. Nov 9, 2024 at 7:05 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
  6. Nov 9, 2024 at 10:15 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I’ve had those KYB’s on my 07 since 2019, but haven't checked them for cracks. Maybe they are now using cheaper materials.
  7. Nov 9, 2024 at 10:18 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    There are these from energy suspension but they don’t have the little bolt head cut outs. I have a set I’ve been meaning to swap.
    https://a.co/d/dkScD94
  8. Nov 10, 2024 at 8:49 AM
    TacoTuesday1
    FL
    I have no idea how my KYB deformed on one side. Bought another. Still need to put it in. Hopefully it’s easy.
    need to come up with a game plan that involves taking apart nothing unnecessary. Done work in the area before.
    maybe if I lift the truck to decompress it, loosen some things, I can sneak it in there.
    To drop the spring out down. Like if I loosen the top, put a jack under the LCA, disconnect it from knuckle, then slowly lower for room.
  9. Nov 10, 2024 at 9:17 AM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    I've kind of done it that way before, lifted the truck, jack under the A-arm pumped up to take the pressure off the top shock hardware a little, loosen up the top center shock bolt while sequentially backing off the jack's pressure on the A-arm and the shock will slowly come apart at the isolator. I still had to remove the bottom shock bolt and move the shock some to get the shock shaft out of the isolator which is still attached to the frame at that point. Putting it back together took 2 people, one to work the jack while other guided the shock shaft back into the new isolator correctly. Obviously a spring compressor is safer and a better idea so I'm not promoting this method but I've been there. At the time we hooked a motorcycle tiedown to the spring through the A-arm in a way that would hopefully retard its energy if it sprang let loose suddenly, luckily it didn't.
