Coil lengths/rate question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DevilTaco4, Aug 16, 2019.
  1. Aug 19, 2019 at 1:00 PM
    #41
    DevilTaco4
    DevilTaco4 [OP] Well-Known Member
    Folsom, CA
    2017 SR Access 5MT
    Well you must be running stock tires then (or close to).
  2. Aug 19, 2019 at 3:06 PM
    #42
    SpeySquatch
    2016 TRD OR DCSB
    265/75/16 with aluminum wheels
    And I have a second set of wheels for winter MT’s that are 255/75/17 with aluminum wheels
    Nobody needs e-rated tires unless they are off-roading on sharp or very hazardous stuff. The only time I’ve popped tires was on the freeway. I don’t rock crawl, I drive forest roads and desert trails
  3. Aug 19, 2019 at 3:16 PM
    #43
    Nexusix
    Nexusix Well-Known Member
    2017 Toyota Tacoma TRD Offroad 4x4
    I have the king setup and went from 600 to 650 spring rate, all I can say is it did make the ride rougher/stiffer, also at higher speeds the steering wheel vibrates and rattles.
  4. Aug 19, 2019 at 3:19 PM
    #44
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    But how does it handle off road?
  5. Aug 19, 2019 at 3:27 PM
    #45
    DevilTaco4
    Folsom, CA
    2017 SR Access 5MT
    I don’t disagree with you. I’d love to find a solid MT in 285/75/16 that isn’t 60+ lbs. Really defeats the purpose when a 315/75/16 is hardly more at 66lbs (Cooper).
  6. Aug 19, 2019 at 3:37 PM
    #46
    SpeySquatch
    2016 TRD OR DCSB
    I don’t understand the wide tire fad
  7. Aug 19, 2019 at 3:56 PM
    #47
    DevilTaco4
    Folsom, CA
    2017 SR Access 5MT
    Just looks a smidge better on a 3rd gens big ‘ole butt. All aesthetics, no ones disagreeing with ya.
  8. Aug 19, 2019 at 4:37 PM
    #48
    SpeySquatch
    2016 TRD OR DCSB
    I think the “looks better” is subjective. When I had wide tires on my 2.4l that stuck out past the fenders I ruined paint on the truck from all the rocks and my dad kicking up...didn’t look so cool then
    A lot of guys run wide tires and if looks are what they are after then it does the job I suppose.
  9. Aug 19, 2019 at 4:47 PM
    #49
    DevilTaco4
    Folsom, CA
    2017 SR Access 5MT
    I prefer a wide(er) stance, not necessarily wide tires. It’s all a balancing game aesthetically speaking. I like that I can run 285s or even skinny 33s on a -12 Ray10 and still have a good amount of poke because I don’t have the fender flares a 3.5 has. I can honestly say I do like the skinny 33 look because its retains a more similar aspect ratio a 35x12.5 has than a 33x11.5. IMO, a 33x12.5 is disgustingly wide to me lol.
    Totally subjective, absolutely.
    SpeySquatch[QUOTED] likes this.
  10. Aug 19, 2019 at 5:37 PM
    #50
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Springs will sag based off the weight of the truck at each corner and the tensile strength in lb/in. So stock is ~690 lb/in and OME is 580 lb/in. You could anticipate compression or sag if you were to corner balance/check the weight on each tire.This is a rough dumbed down estimate and shouldn't be considered absolute, but if the OME coil were the same length as stock it would sit about 15% lower than stock given its lower spring rate. I don't know the stock coil length but I suppose if you knew that you could estimate your actual lift.
    Regardless, if you did end up with a lower than desired lift just drop the shock down and throw a 1/4 spacer on top, that'll bring it up about 1/2" higher. Should fix any issues.
    DevilTaco4[OP] likes this.
  11. Aug 19, 2019 at 7:40 PM
    #51
    DevilTaco4
    Folsom, CA
    2017 SR Access 5MT
    Definitely considering this for simplicity sake. Ahh negatives/consequences to using spacers?
  12. Aug 20, 2019 at 5:50 AM
    #52
    elduder
    Van WA
    Not with a 1/4", it's not really tall enough to cause an issue, unless you're throwing it on a lift thats already 3". You could use a 3/8" as well but will need longer studs, which is a bit more work since you have to remove the top hat from the shock.
  13. Mar 5, 2020 at 10:08 AM
    #53
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    From what I have read, the stock coil has a spring rate of 700 lbs/in and the OME 888 has a spring rate of 590 lbs/in. Therefore the lift provided by the OME coil must be provided by increased spring length and/or preload. I have read that the OME coil has a length of 405mm but I have not found the length of the stock coil. However, I did find a picture of them side by side and observed that the OME coil is longer.
    This was a bit of a surprise for me, because I had previously assumed the OME coil had a greater spring rate. But it all makes sense to me now. The OME coil is designed to compress more for a given bump, thus providing more suspension travel for a given bump. Combined with a greater damping, this provides a better ride on bumpy surfaces.
    The disadvantage is that for a given bit of extra weight the OME coil will compress more, thus the load carrying ability of the truck is compromised. This might be explain the reports of “sagging”. There may also be high speed flat surface ride quality degradation, because the high dampening of little bumps.
    I have long wondered what the advantages of the OME lift kits were besides a small lift. Now I know.
    Please fact check me.
  14. Mar 5, 2020 at 10:47 AM
    #54
    elduder
    Van WA
  15. Mar 5, 2020 at 11:21 AM
    #55
    gudujarlson
    Minnesota
    By “more effective travel” I wasn’t implying that the maximum travel distance of the suspension increases. Perhaps I made a poor word choice. I meant that the shock compresses more when hitting a bump, thus the distance the truck travels downward increases, thus the downward deceleration of the truck is less, and thus the “ride” is less jarring.
  16. Mar 5, 2020 at 2:15 PM
    #56
    elduder
    Van WA
    No, you had it right, lol we both did. I knew that one would go one way or the other. :thumbsup:
