Coil noise help!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by SavageTacoma91, Nov 30, 2015.
  1. Nov 30, 2015 at 11:35 PM
    SavageTacoma91
    SavageTacoma91 [OP] Well-Known Member
    Daniel
    Meadow Vista, CA
    2008 Toyota Tacoma V6 4x4 Access Cab
    Hey guys, I was driving my 97 3.4 5speed tacoma today and it started making this terrible chugging almost knocking noise, but it wasn't quite a knock. I pop the hood and the middle spark plug coil on passenger side is the source! I am not very educated on what could be the problem here, it won't let me post a video of the noise but here is a pic, it looks like it is leaking as well. Thanks in advance!
  2. Dec 1, 2015 at 12:34 PM
    SavageTacoma91
    Daniel
    Meadow Vista, CA
  3. Dec 1, 2015 at 3:42 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    replace it. its arching onto the valve cover.
  4. Dec 2, 2015 at 2:18 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    make sure the plug isn't loose as well
  5. Dec 2, 2015 at 10:37 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    is it just me or does that look like antifreeze oozing down/left from the coil? too thin to be oil............
  6. Dec 2, 2015 at 10:39 PM
    CodeSeven
    Serge.
    Coachella Valley
    shit..... unbolt that 1 bolt, remove the connector, and pull out the coil. see what comes out with it.. I hope it isn't a blown head gasket.
  7. Dec 3, 2015 at 11:00 AM
    SavageTacoma91
    Daniel
    Meadow Vista, CA
    I unbolted it and the spark plug was stripped, someone already tried rethreading the hole but ended up making it too big. Which caused it to strip out, the spark plug is also broken and I guess somewhere in the motor...... My mechanic said i need a new engine :/
  8. Dec 3, 2015 at 11:07 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    did you buy it like this or have you owned it from day one? only reason I ask is who changed the spark plugs may be responsible for the error
  9. Dec 3, 2015 at 11:09 AM
    SavageTacoma91
    Daniel
    Meadow Vista, CA
    I just bought it a week ago. The guy told me it had a replaced motor.
  10. Dec 3, 2015 at 11:34 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    private party? any documentation on the engine?
  11. Dec 3, 2015 at 11:49 AM
    SavageTacoma91
    Daniel
    Meadow Vista, CA
    Private party on Craigslist.
    And yes I had a hand written receipt for it but it looked somewhat fake honestly.
  12. Dec 3, 2015 at 11:50 AM
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    Can't you heli-coil tap the head. Did it damage the motor? If no can't you just slap on a used head on it? I can do a motor swap in that truck the v-6 4x4 in 8 hrs. Id find a better mechanic You can buy a salvage v-6 motor for around $1100.00-1800.00 a 4 banger should be even cheaper! A good head job depending if you can do some of the work $400 or $800 and up!
    Spark plug blow outs are common on the ford triton motors search it. There ways to fix that problem without a motor if the spark plug didn't go into the engine and smash it up. You gonna have to seriously call around and find someone who knows what they are talking about and tiny tip call a couple body shops and ask about there auto\wrecker recycle's they use. Also your own auto insurance companies use these recylers also. And most of the time you can call your agent and ask them to help find you a salvage part and or help locating shops that can do the work the can help! I work in this industry and have major body-shop accounts. You just have to go about it in the right channels. Don't listen to 1 person or place and don't get suckered into towing it all over town either.
  13. Dec 3, 2015 at 8:16 PM
    SavageTacoma91
    Daniel
    Meadow Vista, CA
    Iv always used this mechanic, Iv known him for awhile and he always cuts me a deal an never bullshits me, the spark plug did go into the motor, at least part of it did, he found me a motor at LKQ here in rancho Cordova for 1,100. So I bought that today. Hopefully I'll have the new motor in next week. He's putting a new Aisin clutch kit in, and doing the engine swap for 1,500$
    Blackout14 likes this.
  14. Dec 3, 2015 at 8:22 PM
    SavageTacoma91
    Daniel
    Meadow Vista, CA
    Yes it is! Iv dealt with many mechanics and finally found this guy. Thank god. Thank you all for the replies!
  15. Dec 4, 2015 at 9:28 PM
    preybird1
    Russ
    Salt lake city Utah
    2002 taco s\c
    Ok well that makes more sense. Dam! 3k owww. Agghhh well i Hope the used lump has under 125k on it?
  16. Dec 4, 2015 at 9:50 PM
    SavageTacoma91
    Daniel
    Meadow Vista, CA
    Unfortunately no. It has 223k miles on it. I didn't want to take a huge loss on it so I am fixing it, I may fix it and sell it, or just keep it, I'm not sure yet
  17. Dec 4, 2015 at 9:54 PM
    SavageTacoma91
    Daniel
    Meadow Vista, CA
    I bought it for 4,500 about 2 weeks ago. With supposably a "replaced motor and rebuilt transmission" , once the motor and the clutch is done I'll be into the truck 7,545$...
  18. Dec 4, 2015 at 10:03 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Sorry to hear OP. Hope everything gets sorted out!
  19. Dec 4, 2015 at 10:03 PM
    SavageTacoma91
    Daniel
    Meadow Vista, CA
    Thank you!
  20. Dec 4, 2015 at 10:39 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    This route would have most certainly be cheaper. Not making a point so that you'll feel bad, experience is how we learn after all. I would definitely not pay 1.1k for an engine with 223k miles on it, not even a rebuild. The amount of cylinder and bearing wear/rings (if it hasn't been rebuilt) at over 200,000 miles becomes a factor even on a Toyota engine. Gasket replacements are a given on an engine that old (plus engines like the 22re, 22r, 3vz, 5vz are all known for not being great from the factory with head gaskets).
    Now a rebuilt head and an inspection of the top of the piston in that cylinder would be much cheaper. A new sparkplug and thread insert (because that fastener isn't really load bearing) could have very well solved the problem. Worst case scenario you would need a new cylinder head and and a new piston head for that cylinder (although if it were me I'd just go the extra mile and replace all 6 or 4). The cost for these parts not counting labor would be under $500. But you may not have even needed a new head or piston anyways. Parts break, don't be afraid of a whole engine for a few broken parts, my friend.
    Hope you get your truck running strong with that new motor though, as long as you take care of em with regular maintenance, these little engines DO keep kicking!
