coil over and UCA install video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PacoDevo, Jul 28, 2025 at 1:19 PM.
  1. Jul 28, 2025 at 1:19 PM
    PacoDevo
    PacoDevo [OP] Well-Known Member
    Pops
    Bazetta Twp. Ohio
    2016 SR5 DCLB white "Quinn the Eskimo"
    Going to be installing both new UCAs and coilovers next month. What are some good videos to watch on procedures?? Which should be done first, the UCA or coilover??
    Thanks in advance, Pops
  2. Jul 28, 2025 at 1:20 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
  3. Jul 28, 2025 at 1:45 PM
    808stateofmind
    808stateofmind Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    coilovers are easy, 3 bolts on top, 1 on the bottom, some tutorials will tell you to loosen the LCA bolt to get the bottom of the coilover in, but you can easily pry down on the lca to get the coilover in. make sure you tighten the bottom bolt with the suspension loaded. UCA are way tricker than install videos make it seem, at least for me. They'll say just bend the metal back and slide the bolt out through the engine compartment, but it wasnt that easy for me. you really have to bend the metal out of the way and theres only so far you can go. on the passenger side youve got a/c lines and other stuff in the way of pulling the bolt out easily. same like the coilovers, make sure the suspension is loaded before tightening the through bolt. if you havent considered doing the needle bearing replacement yet, Id definitely recommend it while you already are in there taking stuff apart. you may do all that work and then get vibrations immediately after you lift it.
    BabyBilly likes this.
  4. Jul 28, 2025 at 2:22 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    i had no issue with uca bolt myself. used big pair of channel lock pliers to "peel" the sheet metal outa the way and bolt went right up no issues.
  5. Jul 28, 2025 at 2:27 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    I did the same thing, but some people will more squeamish about bending sheet metal to the degree required.
    Using a rag in the jaws of the channel locks will prevent marring the paint.
    Cutting off the old bolts and replacing them as part of the install is also an option, although you'll have to install the bolt backward from the way it 'ought' to be.
