Coil over Hype...
Discussion in 'Suspension' started by Eesh, Apr 17, 2010.
  1. Apr 17, 2010 at 4:27 PM
    Eesh
    Eesh [OP] Well-Known Member
    Canada
    2025 Tacoma Limited
    I've been chatting on Toyota forums for about 3 years now. I have yet to put a lift on my truck but I have to say that when I first started chatting on TN and TW all the hype was directed towards Coilover type lifts. Now it seems that it has shifted towards OME type shock lift.
    I guess coilovers do serve their purpose for the hardcore off roader. But to guys like me who just want a lift for clearance and everyday driving. I think the OME type set up is better. If a shock goes on you, you get it replaced. If a coil over goes on you, you have to set it away to get revalved.
  2. Apr 17, 2010 at 4:33 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    the lift from OMEs doesnt come from the shock, it comes from the coil. the lift on 5100s comes from the shocks
  3. Apr 17, 2010 at 4:34 PM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    You just compared a type of lift to a brand
    Coilover vs. OME?
    Not sure what you mean by your post
    Unless you are just wanting a shock replacement rather than a coil and shock replacement
  4. Apr 17, 2010 at 4:39 PM
    Eesh
    Canada
    2025 Tacoma Limited
    I actually said "OME type" lift. but I will change it for those of you who have a hard time understanding.
  5. Apr 17, 2010 at 4:46 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Ome type lift is a coilover, just not an adjustable coilover.
  6. Apr 17, 2010 at 5:02 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    exaclty. hell, the truck has coilovers when it rolls off the lot bone stock
    what? your gonna re-valve a spring?
  7. Apr 17, 2010 at 5:21 PM
    Eesh
    Canada
    2025 Tacoma Limited
    Are coilovers not a shock and sping assembled in one unit vs a seperate sping and shock?
    If a shock goes you just buy a new shock if a coilover goes you have to get it revalved.
    shock+spring = $150 per shock on average $75 per spring on average. If a shock goes... you just go buy a new one and replace it all in the same day.
    coilover=$500 per coilover + 40 per coilover every 2 years to get revalved and the hastle of having to wait for it while your truck sits.
  8. Apr 17, 2010 at 5:30 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    OP i understand what youre saying
    youre speaking of the differences between an adjustable coilover vs a non adj. coilover
    it sounds to me like the OME non adjustable is the way to go for you
    i personally dont mind getting my coilovers rebuilt but to each their own
  9. Apr 17, 2010 at 8:29 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    your talking about a re-build, homie
    you re-valve a shock to change it's performance to better suit your needs
    you re-build an adjustable CO when the seals, oil and maybe shaft need to be replaced.
    big difference not only in those 2 terms but also a simple spring and shock assembly and a custom built, OE replacement, race style adjustable coilover
  10. Apr 17, 2010 at 8:45 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I understand what he's getting at... I was in the same boat when searching for a better lift then the spacers I had.
    I wanted coilovers but didnt like the fact that if something broke or wore out I had to send it back to get re-built. But I did want the adjustability bc I wanted to set it where I wanted, and could go back down to stock hight or 2" If I wanted.
    So I opted for the Toytecs, Not re-buildable but they have a life-time warrenty. And since I wont be doing any major offroading, they are awsome for my needs.
    But If you dont need./want the adjustability, the OME lift is for you. Get the same comfort as some great coilovers without the adjustability part. :)
  11. Apr 17, 2010 at 8:53 PM
    TRDguyKC
    TRDguyKC Well-Known Member
    Kris
    Sierra Vista, AZ
    I have an OME lift and i regret doing it..... If i could go back i would have gone coilover. The OME lift is ok, but its still somewhat harsh, and they sag..... an adjustable coil will not settle, and if by chance it does, you can crank it up a little.
    If i were looking to save money and not go full adj coilover, Id just go with a spacer lift and get new shocks.
  12. Apr 17, 2010 at 8:57 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    i can understand what the OP is saying too. having to send off an entire shock to be rebuilt does suck but the benifits of running such a shock far out way that minor detail IMO.
    plus, to break a race style shock (Icon, Fox, King..) or blow a seal (outside normal wear and tear and the general schedule of a rebuild every 1.5-2 years) you have to be beating on your susp really, really hard. it's almost hard to do becuase chances are you'll break a stock piece before the CO.
    it's doesn't sound like the OP is going to be doing serious offroading so he wouldn't have to worry about the shock failing early on him but also if he's not gonna be using them to their potential then why buy them. OME would work fine, like said earlier
