Coil over preload adjustments
Discussion in 'Suspension' started by .jake, Oct 9, 2017.
  1. Oct 9, 2017 at 4:04 PM
    .jake
    .jake [OP] Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    I understand the 5100/6112 clip strategy, but for coilovers like the 2.5 Fox/Icon/Kings/etc... can these be adjusted without compressing or otherwise removing from the truck?
  2. Oct 9, 2017 at 4:10 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Yes. Jack up the truck from the frame so the suspension droops until the tires are just off the ground and you can rotate the adjustment collar with the proper tool. Some have set screws in the collar you need to loosen first.
    Sometimes it’s difficult when you’re dealing with a remote reservoir shock though.
    wheeliest and .jake[OP] like this.
  3. Oct 9, 2017 at 4:17 PM
    .jake
    Makes sense. I'm all stock now, so if I were to put these on now, run them at a "leveling" setting and then later bump them up for another 1" I should be able to do this without compressing or removing, right? (I know it's kinda the same question, bear with me). Thanks
  4. Oct 9, 2017 at 4:18 PM
    Justinlhc
    Correct. Your alignment will change though. You’ll want to figure out exactly where you want to set them before you get an alignment.
  5. Oct 9, 2017 at 4:20 PM
    .jake
    Got it. This is good news. Thanks again.
  6. Oct 9, 2017 at 4:26 PM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    its in your best interest to purchase a life time alignment plan from a automotive shop as if you have any desire to go fast in the dirt due to your upgraded suspension, you will knock the alignment out once a week as i do lol.
    Wile_E_RedDog and .jake[OP] like this.
