coil overs with strut extensions?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by darthnemo313, May 4, 2013.
  1. May 4, 2013 at 7:28 AM
    darthnemo313
    darthnemo313 [OP] Well-Known Member
    Salem, OR
    2011 SR5, BLK, DC, LB
    3 inch lift with Dakar OME Rear Leaf Springs and OME 885 front lift. Also Total Chaos UCA's. Satoshi front grille all black. AFE CAI. AFE EXHAUST.
    Hey all, I have a 2011 taco DCLB with a 3 inch toytec lift, radflo coil-overs with Dakar leaf springs.
    my ride is a little rough especially going over bumps. I was wondering if it is possible to add strut extensions to my coil-overs so I can decompress the springs a little for a smoother ride. I tried to see if any one else has attempted this but haven't found anything.
    thanks!
  2. May 4, 2013 at 7:48 AM
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    Yeah I don't think that's an option. What you can do is get a softer spring rate and replace the coil that's already on there
  3. May 4, 2013 at 8:05 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I think what you are trying to do is replace one spacer lift with another. The toytec spacer preloads the spring which results in a rough ride. There are top plate spacers out there, not sure what company though. But if you get a top plate spacer and ditch the preload spacer your ride will improve. Just remember that with a longer strut assembly you increase the stress on the mounts and could break a shock.
  4. May 4, 2013 at 8:10 AM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    He has the Radflo Coilovers as stated in the OP. my guess is the get longer springs and replace the inches you have now so you don't have to put as much preload on then to et the same amount of lift.
    This is the lift he described:
  5. May 4, 2013 at 2:27 PM
    darthnemo313
    Salem, OR
    My coilovers i have now dont have a spacer in them. They achieve lift by cranking a collar on them down to compress the springs. Same thing as a spacer but you get to adjust your ride height to what you want. I realize that more stress would be added by putting the strut extension on, i just want a happy medium by adding a 1 inch extension or so and letting the coils up a little so the ride is smoother.
  6. May 4, 2013 at 4:30 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    Get a longer spring and problem solved.
  7. May 4, 2013 at 5:01 PM
    darthnemo313
    Salem, OR
    I'll try that. Thanks guys!
  8. May 4, 2013 at 7:21 PM
    NelsonTacoma
    Tucson, AZ
    I guess if I paid more attention I would have seen that! Sorry. But the outcome is still the same. :)
    Let us know how it goes!
